G-code, M-code, and Setting
Service Home 317 - Max User Travel Limit B
This setting lets you define a custom user travel limit (UTL) position for the B axis.
  1. Make sure the work table is clear of any obstructions and clear all of the other user position settings.
  2. Highlight the rotary axis travel limit setting and press [F3] to move the axis to the mount position. Do not move the axis until the part or fixture is mounted.
  3. Mount the part or fixture to the table in the most NEGATIVE position possible for the selected axis.
  4. Jog the axis in the POSITIVE direction to the desired travel limit location. Do not re-zero the machine until all UTL s are set.
  5. Highlight the max rotary axis travel limit setting and press [F2] to set the travel limit. If the tool change offset is not between the Max Rotary UTL and the Min Rotary UTL, a popup will ask for confirmation about resetting the tool change offset for this axis. The minimum travel limit for this axis is calculated to ensure safe zero return and homing.
Press the [ORIGIN] button to set this setting to inactive or set the complete group to inactive.
