G-code, M-code, and Setting
Service Home 377 - Negative Work Offset
This setting selects the use of work offsets in the negative direction.
Set this setting to On to use negative work offsets to move the axis away from the home position. If set to OFF, then you must use positive work offsets to move the axes away from home position.
