G-code, M-code, and Setting
Service Home 409 - Default Coolant Pressure
Some machine models are equipped with a variable frequency drive that allows the coolant pump to operate in different coolant pressures. This settings specifies the default coolant pressure when M08 is commanded. The choices are:0 - Low Pressure
1 - Normal Pressure
2 - High Pressure
NOTE: A P code can be used with M08 to specify the desired coolant pressure. Refer to the M08 Coolant On section for more information.
