G-code, M-code, and Setting
Service Home 420 - ATC Button Behavior
This setting determines the behavior of the [ATC FWD] or [ATC REV] buttons on the control. When this setting is set to Conventional the [ATC FWD] or [ATC REV] buttons behave as normal.
When set to Enhanced mode the [ATC FWD] key will execute a tool change to the next higher tool number into the Pocket Tool Table. It will loop around to the lowest tool number if there is no higher tool number.When in enhanced mode the [ATC REV] key will execute a tool change to the next lower tool number into the Pocket Tool Table. It will loop around to the highest tool umber if there is no lower tool number.
