G-code, M-code, and Setting
Service Home 435 - Indexer Initial Angle A
This setting defines the initial (starting) angular position for the rotary A axis when commanded from the Rotary Indexer incremental move for pre-positioning.
NOTE: The notes below apply to settings 345 to 440.Setting any of the enabled rotary axes Initial Angle or Increment Rotary Indexer User Position settings (435 to 440) to a value enables the Rotary Index functions.
Indexer Initial Angle settings can have valid value of 0 so it needs to be deactivated with Origin to "disable" the value.
Indexer Incremental Angle settings are disabled if the value is equal to 0.
Legacy setting 164 value will be used for fourth axis increments without any initial angle if and only if the User Positions are disabled (backwards compatibility).
