G-code, M-code, and Setting
Service Home 44 - Min F in Radius CC %
44 - Min F In Radius CC %
Minimum feedrate in radius cutter compensation percent setting affects the feed rate when cutter compensation moves the tool towards the inside of a circular cut. This type of cut slows down to maintain a constant surface feed rate. This setting specifies the slowest feed rate as a percentage of the programmed feed rate.
