G-code, M-code, and Setting
Service Home 59, 60, 61, 62 - Probe Offset X+, X-, Y+, Y-
These settings are used to define the displacement and size of the spindle probe. They specify the travel distance and direction from where the probe is triggered to where the actual sensed surface is located. These settings are used by G31, G36, G136, and M75 codes. The values entered for each setting can be either positive or negative numbers, equal to the radius of the probe stylus tip.
You can use macros to access these settings;
for more information, refer to the Macro section of this manual.
NOTE
These settings are not used with the Renishaw WIPS option.
