G-code, M-code, and Setting
Service Home 77 - Scale Integer F
This setting allows the operator to select how the control interprets an F value (feedrate) that does not contain a decimal point. (It is recommended that you always use a decimal point.) This setting helps operators run programs developed on a control other than Haas. There are 5 feedrate settings. This chart shows the effect of each setting on a given F10 address.
INCH MILLIMETER
Setting 77 Feedrate Setting 77 Feedrate
DEFAULT F0.0010 DEFAULT F0.0100
INTEGER F10. INTEGER F10.
.1 F1.0 .1 F1.0
.01 F0.10 .01 F0.10
.001 F0.010 .001 F0.010
.0001 F0.0010 .0001 F0.0010
