4 - Lathe APL - Installation
Lathe - APL - Operator's Manual Supplement
  • 0 - Lathe APL - Table of Contents
  • 1 - Lathe APL - Introduction
  • 2 - Lathe APL - Legal Information
  • 3 - Lathe APL - Safety
  • 4 - Lathe APL - Installation
  • 5 - Lathe APL - Control Icons
  • 6 - Lathe APL - Operation
  • 7 - Lathe APL - Programming
  • 8 - Lathe APL - M-Codes
  • 9 - Lathe APL - Settings
  • 10 - Lathe APL - Maintenance
  • 4.1 Lathe APL - Installation
  • 4.2 APL Bar Stock Template - Installation
The Mill and Lathe installation procedures are located on the Haas Automatic Parts Loader - Interactive Service Manual.  Click on the image below.
AD0478
Install Bar Template
Install the Bar Template Locator[1] with the following hardware:
  • 8 x SHCS 1/4-20
Torque to 13 ft-lbs.
Install the Bar Template Stops[1] and Bar Template Holders[2]. The template is installed depending on the stock size used. This can be found in the Lathe APL Operator's Manual.
Note: Install the templates so the bar stock is equal distance from each other when located against a stop.
Install with the following hardware:
  • 80 x FBHCS 1/4-20
Install Bar Grippers
If the gripper fittings[1] are on the inside of the assembly, rotate the gripper bodies 180 degress so they are facing outside. This will allow for more clearance when loading bar stock.
If the slug style grippers are installed, remove the gripper plates from the gripper bodies.
Install the Bar Gripper Bolt Plates[1] using the following hardware: 8 x SHCS M6[2]
  • Torque to 10 ft-lbs.
Install the Bar Gripper Fingers[3] using the following hardware: 8 x SHCS 1/4-20[4]
  • Torque to 13 ft-lbs.
The location of the bar fingers is dependent on the stock size. The Lathe APL Operator's Manual has recommended locations for specific stock size.
