Desktop Mill - Pen Option- Installation - AD0485
Service Home How To Procedures Desktop Mill - Pen Option- Installation - AD0485
4.2 Desktop Mill - Pen Option
Recently Updated Last updated: 09/26/2022
Desktop Mill - Pen Option - Installation
AD0485
This procedure will show you how to install the pen option on a Desktop Mill.
Assemble the pen assembly as shown
  1. Spring
  2. Pen
  3. Pen holder
  4. ER Nut
  5. 1/4-20 Nut
NOTE: Leave nut [5] slightly loose, it will be tightened when installing into the spindle.
Install pen option by tighening the ER nut into the spindle and then tightening the 1/4-20 nut with a wrench.
NOTE:  When removing the pen option loosen the ER collet first before the 1/4-20 nut to avoid having the holder get stuck in the spindle and keep the assembly together while removing.
Place four 1" X 1" squares of double sided tape onto the back of the provided clipboard.
Once ready for use remove the film of the double sided tape for placement on the table.
Align the clipboard to the table as best as you can and apply pressure to stick the clipboard to the table.
NOTE: When getting ready to load the program it is important to note the spindle will not rotate, the axis should be the only thing moving.
