DS/ST-20/25/Y - Way Cover Curtain Rod Support - Service Kit - AD0925
Service Home How To Procedures DS/ST-20/25/Y - Way Cover Curtain Rod Support - Service Kit - AD0925
- Jump to Section - 1. Introduction 2. Installation (2 steps) 3. Verification Back to Top
Recently Updated Last updated: 04/22/2026
AD0925
Revision A - 04/2026
This kit is for DS/ST-20/25/Y machines with a Gorplate way cover that are experiencing noise when jogging the saddle during rapids. This service kit adds a roller to help support the curtain rod to keep the sheet metal from sagging and causing noise.
This procedure applies to the following service kit:
  • 93-5949 WAYCVR CURTAIN ROD SUPRT DS/ST-20/30/L
With the machine powered off, remove the back enclosure panel [1] to access the the way cover sheet metal.
Install the curtain rod roller support [1] onto the saddle/wedge sheet metal threaded studs and tighten the (2) 1/4-20 flange nuts [2] provided in the kit.
Install the roller bearing [3] onto the support bracket [1] using the 1/4 x 1 1/2 screw [4].
Verification
Turn on machine and run the machine along the X and Z axes, starting at 5% rapid speed and gradually increasing to 100% rapid. While increasing speed, listen for any unusual noise.
If noise is detected, make only minor adjustments by utilizing the clearance in the bracket mounting holes to the threaded studs and at the mounting hole on the bracket to the roller bearing, ensuring proper alignment.
