Haas Bar Feeder - Idler Pulley - Installation - AD0608
Service Home How To Procedures Haas Bar Feeder - Idler Pulley - Installation - AD0608
Recently Updated Last updated: 03/15/2022
AD0608
- Jump to Section - 1. Introduction 2. Idler Pulley Assembly (1 step) 3. Idler Pulley Installation (1 step) Back to Top
This document and service kit applies to Haas Bar Feeders built 02/09/2015 and later:
  • 93-3514 - DRIVE BELT IDLER KIT HAAS BAR FEEDER
Assemble the idler pulley.
Install the Idler Pulley assembly to the center hole on the main chassis plate and torque to 10 Ft-lbs.
Verify that the belt tension is set to the correct tension. See the Haas Bar Feeder - Drive Belt - Replacement procedure for checking and adjusting the belt tension.
Check that the belt does not skip on the motor pulley after installing the idler pulley and setting the belt tension.
