Haas Self Centering Vise - Installation - AD0508
Service Home How To Procedures Haas Self Centering Vise - Installation - AD0508
Recently Updated Last updated: 02/12/2021
AD0508
Install and square the vise.
See video for a how to guide.
Operation
Using a wrench, rotate clockwise to clamp and counter-clockwise to unclamp the vise.
Note: Only use the supplied vise handle for clamping your part. Using a longer wrench will create too much clamp force and will cause premature wear or damage to the ways and lead screw of the vise.
Center the part in the vise jaws. Do not clamp on one side of the vise without a similar sized spacer to evenly clamp the part.
Daily Maintenance
Clean off all chips from the vise after each use.
Maintain the coolant concentration at the correct percentage to prevent corrosion.
Apply a thin coating of rust preventative to all machined surfaces of the vise.
Monthly Maintenance
Remove the chip guard.
Open the vise jaws all the way and remove the jaws[1] by removing the jaw hardware[2].
Clean all chips trapped under the jaws and clean the screw[3].
Apply a thin coating of rust preventative to the screw and machined surfaces.
