High Intensity Lighting - LED Upgrade - AD0418
Service Home How To Procedures High Intensity Lighting - LED Upgrade - AD0418
Recently Updated Last updated: 11/28/2018
High Intensity Lighting LED Upgrade
AD0418
- Jump to Section - 1. HIL LED Upgrade (3 steps) Back to Top
HIL LED Upgrade
With the machine power off, unplug and remove the old style halogen HIL light assembly [1].
Install the replacement LED HIL light assembly [2].
Remove the wire channel cover [1].
Use cable 79-5803 [2] to spice into the power cable to the light. Do not cut off power to the second light.
Use the caps [3] to crimp the wires together.
If the machine is equipped with the older style HIL that uses a roller switch to activate the lights:
Remove the halogen style light [1] from the arm.
Use a 1/4" drill bit [2] to drill a new mounting hole on the face of the arm.
Install the LED [3] on the arm.
Wire the 79-5803 power cable [4] as illustrated.
Drill or notch the arm cover for the power cable.
