Lathe - Bar Feeder Chamfer Device - Installation - AD0744
Service Home How To Procedures Lathe - Bar Feeder Chamfer Device - Installation - AD0744
Recently Updated Last updated: 03/06/2024
AD0744
- Jump to Section - 1. Introduction 2. Installation (9 steps) 3. Verification Back to Top
This procedure will show how to install a Chamfer Device onto a Bar Feeder for both the service kit and the purchased option.
Machine Compatibility:
  • ST-10/15/20/25/28/30/35/L/Y/LY with Haas Bar Feeder
  • ST-20/30/SS/Y/SSY with Haas Bar Feeder
  • DS-30Y with Haas Bar Feeder
  • 93-1001009 BAR CHAMFER FIELD INSTAL KIT BARFEED
 Note: This procedure uses a ST-20 for illustrative purposes. The same applies to all machines listed above unless otherwise specified.
Press [EMERGENCY STOP].
Remove Bar Feeder table cover [1].
 Note: Bar Feeders bought with chamfer option will not require this step. The table will come with holes for mounting the chamfer machine.
For kit P/N 93-1001009:
Place the template [1] on the Bar feeders second rail [2], closest to the machine.
Use the template to mark the four holes.
Remove template then drill 5/16th holes in the marked locations.
Deburr both sides of each hole.
Route power cable [1] through the bottom opening [2] of the control cabinet, under the side skirt [3], and behind the Bar Feeder's back panel [4] next to the corrugated tubing [5].
 Note: Bar Feeders bought with chamfer option will come with the power cord already routed through the corrugated tubing [5] which should be installed using the steps in the Haas Bar Feeder - Installation procedure.
Leave the cable disconnected from power.
Install the chamfer cutter [1] onto motor shaft [2] by lining up the key way [3].
Snug the bolt [4] hand tight. Verify that the chamfer cutter is securely attached to the motor shaft.
Bolt the chamfer device [1] onto the underside of the Bar Feeder table.
Updated
Plug the foot pedal cable 33-1293 [1] into the chamfer device cable 32-1296 [3] and power cable routed through the control cabinet 33-1303 [2].
 Reference name on cable to verify correct location.
Remove the Bar Feeder’s back panel [1].
Use the self-tapping screws and cable clamps [2] to secure the power [3] and foot pedal [4] cables to the support bar [5] on the underside of the table.
Updated
Attach the foot pedal cable [1] to the Bar Feeder using two of the three cable clamps [2] behind the Bar Feeder back panel.
Note: The foot pedal may be positioned at the operator’s discretion for optimal accessibility. Securing the cable with the provided clamps is optional and may be omitted if additional cable length is required to place the pedal closer to the operator.
Install the Bar Feeder's back panel [1].
Attach the power cable [2] to the corrugated tube [3] between the machine and Bar Feeder using zip ties [4].
 Note: Bar Feeders bought with chamfer option will have the power cable routed through the corrugated tube [3].
Plug power cord into control cabinet [5].
Verification
Step on the foot pedal to verify the chamfer machine turns on.
The cutting surface should rotate counter clock-wise.
