Linear Scale - Stable Position - Test - 1997
Service Home How To Procedures Linear Scale - Stable Position - Test - 1997
Recently Updated Last updated: 12/01/2018
- Jump to Section - 1. Linear Scale - Stable Position - Test Back to Top
The following procedure should be applied to a scale mill after updating to the latest scale design. This assumes that:
A. Software release 10.13 or later has already been installed in the machine.
B. All parameters have been checked and are correct
C. The machine has been zeroed.
Perform the following:
  1. Turn Setting 7 PARAMETER LOCK to OFF.
  2. At the Alarms display, type “DEBUG” and press [ENTER].
  3. Select position display.
  4. Press page up until displayed titled “UNUSED”.
  5. Jog the X axis the plus travel limit.
  6. Observe the X axis Z CH TRAV displayed value, it must be stable after a few seconds to +/-1, if not there is a problem, check your work.
  7. Jog the X axis to the opposite (minus) end of travel.
  8. Observe the X axis Z CH TRAV displayed value, it must be stable after a few seconds +/-1, if not there is a problem, check your work.
  9. Repeat steps 5 through 8 for Y and Z axes.
  10. At the Alarms display, type “DEBUG” and press [ENTER].
For as long as practical, test the scales by cycling all axes as far and as fast as possible.
