Low Voltage Power Supply (LVPS) - Replacement - CHC - AD0059
Service Home How To Procedures Low Voltage Power Supply (LVPS) - Replacement - CHC - AD0059
Recently Updated Last updated: 05/27/2026
AD0059
Revision C - 05/2026
- Jump to Section - 1. Introduction 2. Replacement (3 steps) Back to Top
This procedure tells you how to replace a low voltage power supply (LVPS) in Haas machines that have a Mocon Revision K or lower.
Prerequisites
This kit includes cables to install the LVPS in different configurations. After you identify your configuration and install the cables necessary, discard the rest of the cables.
Replacement
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Danger: If the voltage indicator light is on, do not touch the electrical components. The high voltage in the control cabinet can kill you. Wait for the voltage indicator LED to go off fully.
Caution: When you touch electronic components, use an electrostatic discharge strap.
If the machine has the optional PFDM [2], do these steps :
  1. Disconnect these cables [1] from the PFDM:
    1. 120 VAC In
    2. PWR Analog Sense Signal
    3. DC Out PWR to LVPS
  2. Remove the PFDM.
Remove the LVPS and attached bracket [1].
Caution: Before you remove the screws, make sure you hold the LVPS and attached bracket.
If the LVPS has other cables [2], record where they are connected and remove the cables.
Remove the LVPS [3] from the bracket [4].
Install new parts in the reverse order you removed the old parts.
Note: All of the cables are not always used in each installation.
Push [POWER ON]. Measure the output voltage from the new LVPS. Make sure the output voltage is correct
