    2. Українська
    2. Українська
Mini Conveyor Belt Service Kit - AD0693
Service Home How To Procedures Mini Conveyor Belt Service Kit -AD0693
Recently Updated Last updated: 01/31/2024
Mini Conveyor - Belt Service Kit
AD0693
- Jump to Section - 1. Introduction 2. Removal (8 steps) 3. Installation (7 steps) Back to Top
  You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
   Only authorized personnel with the proper training and certification should do this repair procedure.
   All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
This procedure will guide you on how to replace the belt on the Haas Mini Conveyor.
This document applies to the following parts:
  •   93-3748 MINI CONVEYOR BELT SVC KIT
Removal
Remove the two wings from the chassis
Back out the Tensioning Screws and Jamnuts on both sides to release tension from the belt.
Remove the tension springs from the tensions brackets.
Remove the 1/4-20 nut and tensioning brackets from both sides of the inner tensioning rod.
Slide the roller towards the opening in the chassis and remove the inner tensioning rod from the rod sleeve.
Loosen the setscrews [1] on both hubs. Remove the support pin and brass bushing [2] from the Drive rod.
Slide the drive rod away from the motor shaft  and lift from the chassis.
Remove the drive shaft and tension shaft from the old belt.
Install the drive rod assembly through the belt and onto the motor shaft.
Insert the Rod Sleeve in the belt [1], install the Inner Rod through the opening in the chassis and into the Rod Sleeve.
Attach the Tensioning Brackets to both ends of the Slave Rod assembly.
Install the Tensioning Screws and Springs with Jamnuts to both sides and evenly tension the belt.
Use vice grip clamps or c-clamps to compress the Springs between the Tensioning Brackets.
Install the brass bushing and support pin:
  • Align the two holes shown
  • Tighten the setscrews on both sides
Install the two wings onto the chassis:
  • Power up the motor and let the conveyor run to test the tension of the belt
  • Adjust if necessary
