Date/Time Change - NGC
Service Home How To Procedures Date/Time Change - NGC
2.4 Date/Time Change - NGC
Recently Updated Last updated: 02/02/2021
Set the Date and Time
Push [POWER ON].
Push [CURRENT COMMANDS]  [1].
Select the Timers tab [2].
Select the Date: option [3].
Push [EMERGENCY STOP].
Type today's date in this format: MM-DD-YYYY(Month-Day-Year) [5].
 Note: Make sure not to put a future date. You will not be able to change it back.
Push [ENTER].
A Warning screen shows [4]. Push [ENTER].
 Note: Software version 100.16.000.1010 and higher does not have a Warning screen.
Select the Time: option [1].
Type current time in this format: HH:MM (Hour:Minute) [3].
Push [ENTER].
A Warning screen shows [2]. Push [ENTER].
Select the Time Zone: option [1]. Push [ENTER].
Select your time zone.
You can also use the Search [2] function to find your time zone [3].
Push [ENTER].
Power on the machine.
 Note: For software version 100.16.000.1010 and higher, it is not necessary to power off and power on the machine.
Real Time Clock (RTC) Failure
The Real Time Clock (RTC) Failure screen can show when you start the machine. If this occurs, enter the correct time and date again.
Push [ENTER].
