ST-30/35 - Sub-Spindle B-Axis Switch Relocation - AD0621
Service Home How To Procedures ST-30/35 - Sub-Spindle B-Axis Switch Relocation - AD0621
Recently Updated Last updated: 06/15/2022
AD0621
- Jump to Section - 1. Introduction 2. Switch Removal (1 step) 3. Switch Install (2 steps) Back to Top
This document and service kit applies to machines built between 3/27/19-9/1/21 with 25-13522 PROX SWITCH FLAG LATHE B-AXIS & 25-13540 INTRNL PANL BS COVER MOUNT RIGHT ST20/:
  • 93-3516 B-AXIS SWITCH RELOCATION SVC KIT ST-30
Switch Removal
1.  Remove the hardware for the Ball Screw Cover.
2.  Remove the hardware from the front of the Ball Screw Cover and pull the Cover forward to access the Switch Assembly.
3.  Unplug the home switch noting the connector locations and remove the Switch Assembly.
4.  Remove the Switch Flag.
Switch Install
1.  Install the Switch and Grommet to the new Ball Screw Mount.
2.  Install the Switch Assembly and route the home switch cable through the grommet and connect the Home Switch connectors labeled NC and COM to the correct connectors on the home switch.
3.  Install the new Switch Flag.
1.  Slide the Ball Screw Cover back into place and install the Switch Cover.
2.  Install the Ball Screw Cover hardware.
Perform the Axis Grid Offset - NGC procedure for the B-Axis after installing the switch assembly.
