UMC - Standard and Filter Conveyor - Installation - AD0748
Service Home How To Procedures UMC - Standard and Filter Conveyor - Installation - AD0748
- Jump to Section - 1. Introduction (4 steps) 2. Installation (4 steps) 3. Parameter Updates Back to Top
Recently Updated Last updated: 10/09/2025
UMC - Standard and Filter Chip Conveyor - Installation
AD0748
Revision A - 10/2025
This procedure outlines how to install the Standard Conveyor and the Filter Conveyor on UMC Machines.
Reference the following link to identify your conveyor UMC CONVEYOR IDENTIFICATION
This procedure applies to the following Standard Conveyor service kits:
  • 93-1000325: CHIP CONV UMC-500 POST 12/2019
  • 93-1000218: CHIP CONV UMC-1000
  • 93-1001030: CHIP CONV KIT UMC-1250
UMC-750s built before 04/29/2022:
  • 93-1000207: CHIP CONV UMC-750 REBOOT
UMC-750s built on or after 04/29/2022:
  •  93-1001299: CHIP CONV 8" WIDE KIT UMC-750 RBT
This procedure applies to the following Filter Conveyor service kits:
  • 93-1000936: CHIP CONV FILTER 10" WIDE UMC-500
  • 93-1000922: CHIP CONV FILTER 10" WIDE UMC-750
  • 93-1001041: CHIP CONV FILTER 10" WIDE UMC-1000
  • 93-1000962: CHIP CONV FILTER 10" WIDE UMC-1250
  • 93-1000963: CHIP CONV FILTER 10" WIDE UMC-1500-DUO
Important: When installing a FIlter Conveyor on a UMC-500 with a 95 gallon coolant tank, a chip hopper will be required.
Unfold the standard conveyor and place the conveyor in position, using a big joe or a forklift attach straps to the lifting hooks [1] and support the other end of the conveyor [2] to begin sliding the conveyor into the casting.
Note: The Filter Conveyor will not need to be unfolded to install.
Install the conveyor brackets [1] as shown. There should be two (2) brackets on each side for a total of four (4) brackets attached.
Install the drain pan [2] and its adapter brackets [1].
Connect the chip conveyor to power by routing the cable as shown [1] to ensure the cable does not get pinched or damaged.
Parameter Updates
Turn on the machine.
Login to the HBC PORTAL.
Download the patch file.
 Note: The option files will appear on the configuration download page after the service kit has been ordered. If the option does not appear, contact the service department.
Load the option configuration patch file to the control. Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
