UMC Thermal Growth Sensor Removal - AD0515
Service Home How To Procedures UMC Thermal Growth Sensor Removal - AD0515
Recently Updated Last updated: 10/16/2024
UMC Thermal Growth Sensor - Removal
AD0515
- Jump to Section - 1. Introduction 2. Removal (7 steps) 3. Patch Directory Back to Top
The thermal growth sensor is being removed from all UMC models.
If the customers is experiencing repeatability or parts out of spec due to the thermal sensor they can disable the sensor one of two ways.
Machines built before 10/2021 will need a patch to disable the sensor.
 NOTE: If customers are not experiencing issues with the sensor enabled DO NOT disable.
Machines built after 10/2021 will need to reload configuration files.
The hardware can stay on the machine.
Removal
The thermal growth sensor mounts directly to the spindle head casting. To access the casting you will need to remove the coolant knob [1] and spindle head covers [2 & 3].
Remove the Peel & Seal patches shown [1 & 2]
Disconnect the sensor cable from junction box/panel shown in the image. The sensor connection should be in the spare sllot #2  highlighted in re
Once disconnected, feed the sensor cable down the head to the sensor itself.
Remove cable 33-2232  from the junctions box/panel and  unplug cable 33-2232 from P45 on the I/O board.
Remove cable 33-2232 from the machine.
This is a view from inside the spindle head casting.
Remove the smaller Peel & Seal patch from the mounted sensor inside the casting [1].
Remove the thermal growth sensor from the casting.
Apply replacement Peel & Seal patches to the openings shown.
Re-install the spindle head covers and coolant knob.
Patch Directory
Machines built after 10/2021 will need to redownload the configuration file and the necassary  parameters will be updated. However, machines built before 10/2021 will need a patch to disable the sensor.
Reach out to Haas through HBC to get the correct patch files for your machine.
Make sure to include the reason for needing to disable the thermal growth sensor as well as an error report from the machine to provide them with all the information needed.
Machines built after 10/2021  need to redownload the configuration files on to the machine. However, machines built before 10/2021 will need a patch file to get the necessary parameters changed.
Contact Haas through HBC to get the patch file for your machine. Make sure to include the reason why the thermal sensor needs to be removed as well as an error report of the machine.
