Coolant Sanitizer - Maintenance - RD0083
Service Home Coolant Sanitizer - Maintenance - RD0083
21.4 Coolant Sanitizer - Maintenance
Recently Updated Last updated: 10/24/2025
RD0083
Overview
Proper maintenance ensures that the pump is running efficiently and effectively. We reccomend to do the following steps everytime the pump is remove from the coolant tank to avoid the following :
  • Excessively loud/noisy pump
  • Poor sanitization effectiveness / loss of performance.
Warning : Disconnect the power supply from all component before doing any maintenance.
Remove the pump cover [1] to gain access to the inside of the pump and clean it from any debris or metal chips. Check the flow control valve [2] for any blockage and make sure it clean it periodically.
Note : The pump should never be powered on unless it is submerged in fluid.
Important : The flow control valve [2] is fixed and cannot be adjusted. Doing so can cause damage to the submersible pump and reduce the effectiveness of the system
Check if the ozone tube [1] is pinched or damaged along its entire length.
Note : Discoloration of the clear tube over time is expected due to the ozone.
