Renishaw – WIPS-RF - Radio Machine Interface (RMI) - Lights Information - RD0056
Service Home Renishaw – WIPS-RF - Radio Machine Interface (RMI) - Lights Information - RD0056
Recently Updated Last updated: 10/17/2025
RD0056
Overview
The probe has (8) LEDs. The LEDs flash in different colors and different lengths of time. The sequence that the LED flashes tells you the probe settings.
The LEDs flash these colors:
  • Red
  • Green
  • Blue
  • Yellow
The LEDs flash a short or a long time. In the tables that follow, a small colored circle shows that the LED flashes a short time . A rectangle shows that the LED flashes a long time .
Look at the probe LEDs. Record the color and length of time that the LEDs flash.
The meaning of the color and the length of time that the LED flashes is important. Refer to the table for the meaning.
Number in the Illustration LED Name LED Color This tells you this information:
1 Probe 1/2/3/4 OFF Probe number empty
Yellow  Probe number full, in standby
Green  Probe number full, in operating
Red  System Error. See Installation Guide
Yellow , Yellow , Yellow  Selection error
Green , Yellow , Green , Yellow , Green  Parnering/clearing pending, full
Green , Green , Green  Partnering pending, empty
Red , Yellow , Red , Yellow , Red  Partnering complete, probe full
Green , Red , Green , Red , Green  Probe authentiction error
Red , Red , Red  Clearing complete, probe empty
2 Signal LED OFF  No probes operating
Good communications
Poor communications
Red , Red , Red  Overload error
3 Error LED OFF No error
Red  Error
Red , Red , Red  System error. See Installation Guide
Overload error
4 Probe Status LED Red  Prode triggered
Green  Probe seated
Overload error
5 Low Battery LED OFF Battery is okay and no M code start/stop in progress
Red  Battery low
Green  M code start/stop in progress
Yellow  Battery is low and M code start/stop in progress
 Notes:
  • The Probe Status LED is always illuminated when power is present at the RMI-QE.
  • All LEDs report the status of the partner radio probe. if there is no partner or the partner is off, then the Probe Status and Error LEDs will illuminate red. The Low Battery and Signal LED will be off.
  • When the RMI-QE is powered on, each of the eight LEDs will flash orange in sequence starting from the top left and finishing at the bottom left. After this it will enter the acquire partner mode. This is indicated by a flashing green Signal LED. After approximately 60 seconds it will switch to its normal mode listening for its partner.
