Renishaw Probe – WIPS-RF - RTS – Settings - RD0055
Service Home Renishaw Probe – WIPS-RF - RTS – Settings - RD0055
Recently Updated Last updated: 10/17/2025
RD0055
Revision A - 4/2025
Overview
The probe has one LED. The LED flashes in different colors and different lengths of time. The sequence that the LED flashes tells you the probe settings.
The LED flash these colors:
  • Red
  • Green
  • Blue
  • Yellow
  • Cyan
The LED flashes a short or a long time. In the tables that follow, a small colored circle shows that the LED flashes a short time . A rectangle shows that the LED flashes a long time .
Look at the probes LED. Record the color and length of time that the LED flashes.
The meaning of the color and the length of time that the LED flashes is important. Refer to the table for the meaning.
The probe settings are in (1) group:
  1. Enhanced Trigger Filter
LED Check
The probe does a check of the LED. It does this before it shows the values of the settings.
The LED flashes in this sequence: Probe State:
, , , , ,  The LED operates correctly.
, ,  The trigger filter is off. This is the initial setting for Haas machines.
, ,  The trigger filter is on with a nominal 6.7 ms delay to the probe output.
Pairing Mode
, ,  The pairing mode is off.
, ,  The pairing mode is off and the RMI-QE is found. (RMI-QE only)
, ,  The pairing mode is active.
, ,  Pairing was successful.
Operating Mode
, ,  The probe is seated in operating mode.
, ,  The probe is triggered in operating mode.
, , , , ,  The probe is seated in operating mode with a low battery.
, , , , ,  The probe is triggered in operating mode with a low battery.
The battery is dead.
, , , , , , ,   or
, , , , , , ,   or
, , , , ,  (sequenced when batteries are inserted)
The battery is unsuitable.
Battery Status
Probe State:
, , , ,  The battery is good.
, , , , , , , , ,   or   , , , , , , , , ,  The battery is low.
Master Reset
, , , , , , ,  The probe's previous settings have been cleared. The probe is reset to the default settings.
