Haas Control Software Revision Numbers - NGC - RD0063
Service Home Haas Control Software Revision Numbers - NGC - RD0063
3.1 Haas Control Software Revision Numbers
Recently Updated Last updated: 10/17/2025
RD0063
The numbers for the Next Generation Control software version are different than the numbers for the Coldfire software version.
These are examples of the Coldfire software revision numbers:
  • Mill: 18.19B
  • Lathe: 11.16B.
There is two different types of Next Generation Control software:
  • NGC 15-Inch: In production between 2015 and 2025.
  • NGC 19-Inch: In production starting 2025.
This is an example of the Next Generation Control software revision number:
  • 100.15.000.0000
 Note: 15-inch machines are not compatible with 19-inch software, and 19-inch machines are not compatible with 15-inch software. Never install the wrong type of software onto a machine. It may not be possible to recover, and many expensive components may need to be replaced.
The software revision number has these (4) sections.
  • A. The first 3 digits do not change.
    • 100 is for mills/lathes/simulators.
  • B. The 2-digit pair tells you the year.
    • For example, 15 is for 2015, and 16 is for 2016.
  • C. The 3-digit group is used to differentiate between 15-Inch and 19-Inch.
    • Machines with "000" are 15 Inch.
    • Machines with "001" are 19 Inch.
  • D. The 4-digit group has these (3) sections:
Major = .0000
  • 0: Beta software
  • 1: First production release.
Minor = .0000
  • This number increases one increment every quarterly release.
Sub = .0000
  • This number increases one increment when ever there is a necessary feature or correction.
These are examples of how the software revision number changes.
  1. 100.19.000.1100 This software version is schedule for release at the end of March - mid April 2019.
  2. 100.19.000.1200 This software version is schedule for release at the end of June - mid July 2019
