19" LCD Monitor / SKBIF - Troubleshooting Guide - TG0008
Service Home 19" LCD Monitor / SKBIF - Troubleshooting Guide - TG0008
- Jump to Cause - Back to Top
19.4 - 19" LCD Monitor / SKBIF - Troubleshooting Guide
Recently Updated Last updated: 10/08/2025
19" LCD Monitor / SKBIF - Troubleshooting Guide - NGC
TG0008
Revision C - 12/2025
SKBIF Inspection Report Checklist
Download and fill out the SKBIF Inspection Report Checklist below before replacing any parts.
[1] 19" LCD.
[2] 19" Touchscreen LCD.
NOTE: The LCD touch screen has a USB cable that plugs into the SKBIF PCB.
[3] SKBIF PCB
[4] Handle Jog
[5] E-Stop Button
[6] Power Off
[7] Power On
Alarm 825 USER INTERFACE COMMUNICATION FAULT There is a problem with the communication cable from Main PCB to SKBIF PCB. The communication between the Main PCB and SKBIF PCB is lost or no signal. Check the RJ45 cable connected to SKBIF at J28 to Main PCB J9, make sure the cable is not damaged or it has a loose connection. To test the cable refer to Network Cable Tester Tool procedure.
Machines with SKBIF Version 6.xx.  Alarm 546 SERIAL KEYBOARD COMMUNICATION FAULT. The SKBIF firmware is outdated. Make sure you have SKBIF firmware version 6.6 or higher.  Refer to SKBIF PCB / RJH Firmware Update - NGC procedure.
The LCD turns to a black screen. Alarm 967 SKBIF COMMUNICATION FAULT. There is a problem with the communication cable from Main PCB to SKBIF PCB. See SKBIF Troubleshooting section below.
The supply voltage from PSUP PCB to SKBIF PCB is not correct.
The backlight and HDMI cables are not connected correctly.
The wires to the [POWER ON], [POWER OFF], [EMERGENCY STOP], [FEED HOLD] and [CYCLE START] contactors terminals are loose.
The beacon light does not turn on. The beacon light cable is not connected. Make sure the beacon light is connected to SKBIF at P10.
The control has a blurry screen.
A switch on the SKBIF is not correctly set.
Change the MAPSEL switch to the opposite position. See the section below.
The screen flickers during spindle deceleration (running spindle then pressing "Reset" key) or during heavy cuts. The cable from the Maincon PCB connected J9 to the SKBIF at J28 is defective.
  1. Check the RJ-45 cable connection from Maincon PCB (J9) to SKBIF PCB (J28). To test the cable refer to Network Cable Tester Tool procedure.
  2. Inspect the RJ-45 connector housing on the Maincon PCB & SKBIF PCB for bent pins.
The RJ-45 connector housing is damaged on the SKBIF or Maincon PCB. Make sure the RJ-45 connector housing is solder to the PCB and not loose.
You get a blank screen with continuous beeping at power on. The jog handle or wiring is defective.
  1. Power off the machine.
  2. Check the wiring to the jog handle, make sure all the cables are connected in the correct location.
  3. Set the meter to ohms, measure resistance between front panel ground to the +5Vdc of jog handle - it should not read zero ohms. If shorted, disconnect the +5Vdc wire from the Jog Handle and check if the problem is the jog handle or the SKIBF.
Alarm 2001 EMERGENCY STOP SWITCH ERROR
There is a loose connection from the E-stop button to the SKBIF PCB.
  1. Go to Diagnostic Page --> Keyboard I/O
  2. Type REDUNDANT_ESTOP then press [F1].
  3. With [EMERGENCY STOP] released the INPUT #26 REDUNDANT _ESTOP value should = 1.
  4. Press [EMERGENCY STOP].  The INPUT #26 REDUNDANT _ESTOP value should = 0. If it remained = 1 check the cable plug to SKBIF J26 see diagrams located at the end of this Troubleshooting Guide.
Seized hydraulic union triggered Hydraulic Union Safety Device.
Only applies to these machines built after 12/20/2023:
ST - 10/15/20/25/28/30/35/L/Y/LY
REBOOT ONLY: ST-40/40Y/45/45Y (note: For ST-45/45L/45Y machines equipped with optional workholding)
Check the Hydraulic Union Safety Device cable attached to the hydraulic union drain hose.
There is a loose connection from the Hydraulic Union Safety Device adaptor to the I/O PCB.
Check the cable connected to the I/O PCB at P12, make sure the cable is not damaged or has a loose connection. Refer to the I/O PCB - Troubleshooting Guide - NGC.
LCD Touchscreen.  Turned setting 381 to On, but the touchscreen does not respond to touch commands. The touchscreen feature is not enabled. To enable the Touchscreen set setting 381 Enable Touchscreen to On.
The configuration files are outdated. Parameter 2257 Touchscreen Support must be set to TRUE. If not you will need to contact the service department to have it enabled.
Too much electrical noise in the system. Add ferrites to two SKBIF USB cables. Refer to the SKBIF Reduce Electrical Noise section below for more information.
The touchscreen continues to function after turning Setting 381 to OFF. The control does not recognize the touchscreen module.
Unplug the Touchscreen USB cable from the top port at J11 on the SKBIF PCB.
Plug the touchscreen USB cable back into the SKBIF PCB at J11, and turn Setting 381 to OFF.
LCD Touchscreen
The TouchScreen does not respond to touch commands.
The touchscreen is not calibrated. Use the touchscreen configuration page to calibrate, test, and restore default settings.
The touchscreen configuration is located in the maintenance section.
Press [DIAGNOSTIC] to go to the Maintenance and navigate to the Touchscreen tab.
Follow the instructions on the screen.  After calibration you need to cycle power.
The touchscreen USB cable is not connected correctly to the SKBIF PCB. Make sure that the USB cable connection is connected to J11 at SKBIF PCB.
LCD TouchScreen.
Some tabs look dark as they have been pushed.
This is normal,  this is used to distinguish the family of tabs the current screen is showing.
The sound of the beeper only works when I power on the machine. The beeper volume setting is turned off. Go to setting 356 and set to a value higher than 0.
The beeper volume is low or inaudible. The SKBIF PCB or beeper is defective. Machines with SKBIF (34-4510) PCB the beeper is built into the SKBIF.  This beeper can't be tested,  check for voltage going to the SKBIF, if everything checks out ok then the SKBIF PCB is defective. Note:  Do not replace the speaker,  the speaker does not produce the beeper sound.
The monitor is flickering. Heat and vibration is causing the electrical tape to loosen around the HDMI cable. Add cable clamp 59-2040 at the base of the HDMI cable where the tape used to be to secure the cable.
The monitor is blank while the control is on.
The HDMI cable has been cut or broken.
The HDMI cable will be need to be replaced:
If customer needs 79-0186 replaced, use 79-0186A.
If customer needs 79-0189 replaced, use 79-0189A.
If customer needs 79-0191 replaced, use 79-0193A.
If customer needs 79-0192 replaced, use 79-0192A.
If customer needs 79-0193 replaced, use 79-0193A.
After upgrading to SKBIF Firmware Version 6.8 there is a longer delay between pressing the [Power On] button and seeing something on the LCD display. This is normal behavior. The beacon will blink during this time to indicate the machine is turning on.
PCB serial number
Note: The PCB's serial number must be included in the inspection report checklist. The serial number is on a sticker [1] on the PCB.
The serial number will start with two letters, followed by eight digits. Include both the letters and numbers on the inspection report.
  1. Remove the LCD back cover.
  2. Check J13 backlight and J11 connectors. Make sure the connectors are seated, and wires are not broken.
  3. Check the wires going to the [POWER ON], [POWER OFF], [EMERGENCY STOP], [FEED HOLD] and [CYCLE START]
    contactors. Make sure the connections are tight.
  4. Look at the status LED lights.  Refer to the LED table below.
  5. Set the volt meter to DC. Check for +12Vdc supply voltage at J20 you should measure approximately +12Vdc. If this voltage is lower than +11Vdc or not present make sure J20 connector is properly seated, and trace the voltage back to the LVPS. Refer to the above electrical diagram.
  6. The SKBIF PCB generates +3.3Vdc, +5Vdc. Check these voltages at the following test points.
    • Put the black probe on the screw (ground) [4] and the red probe at TP14 (+3.3Vdc) [1] you should measure approximately +3.3Vdc.
    • Put the black probe on the screw (ground) [4] and the red probe at TP13 (+5Vdc) [2] you should measure approximately +5Vdc.
    • Put the black probe  on the screw (ground) [4] and the red probe at TP12 (+12Vdc) [3] you should measure approximately +12Vdc.
    If these voltages are low or no voltage is measured, disconnect all the connectors from the SKBIF PCB except the J20 connector, and measure again. If after doing this there is still no voltage then the SKBIF PCB is defective.
    If after disconnecting the components, the voltages are correct, then there is a short circuit in one of the components connected to the SKBIF for example, remote jog handle, handle Jog, etc. Determine which component is at fault.
     If everything checks out ok, then the SKBIF PCB is defective.
    NOTE: Do not replace the speaker, the speaker does not produce the beeper sound.
LED Table
The following table applies to -4510X SKIBF PCB.
LED# Status Corrective Action
LE1 (PASS/EQ, Lock) Amber This is normal condition. The SKBIF and Main PCB are communicating.
LE3 Sync Green
LE1 (PASS/EQ, Lock) Red The communication between the Main PCB and SKBIF PCB is lost or no signal. Check the RJ45 cable connected to SKBIF at J28 to Main PCB J9, make sure the cable is not damaged or it has a loose connection. To test the cable refer to Network Cable Tester Tool procedure.
LE3 Sync OFF
PCB Component Inspection
Intermittent symptoms or alarms can be caused by component failure. Below is a list of possible failures:
  1. Missing solder on all or some components pins
  2. Poor solder
  3. Solder bridges
  4. Wrong component installation (orientation)
  5. Missing components
     Note: Some PCB's have unused circuits and are missing components intentionally, look for broken off components.
  6. Broken components
  7. Broken pins on IC's
  8. Bent pins on the connectors
Use a magnifying glass to inspect the circuit components on the front and back of the SKBIF PCB. Below are the circuit component zones to inspect:
  1. Inputs connectors (Keyboard, E-stop, Power On/OFF etc.)
  2. RJ-45 connector (SKBIF PCB communication with Maincon PCB, LCD Data)
  3. LCD circuit components (LCD Backlight, LCD Data).
  4. Inspect all solder joints for missing solder.
 Important: If you find a damaged component, replace the SKIBF PCB, inspect the new SKBIF PCB circuit components before installing.
Electrical Diagrams
SKBIF / 19" LCD Interconnect Diagram
SKBIF Diagram P/N 34-4510C
Note: Machines with SKBIF 34-4510C will have the USB Charging Port connected to J3. The Charging Port is only for charging purposes and not for getting data from USB devices.
Pendant E-Stop Circuit Diagram
PSUP (P16) to SKBIF (J5) Detailed Diagram
PSUP (P17) to I/O PCB (P56) Detailed Diagram
