Lathe APL - Bridge Shim
Service Home Service Alerts/News Lathe APL - Bridge Shim
March 16, 2020 Lathe APL - Bridge Shim
This News has been posted for more than 90 days.
Be advised that the information displayed may not be current and valid. Service News information is subject to change.
When we are building the APL we will shim between the bridge and the column as needed to set the AU axis square to the AW axis. Then when the bridge is lowered to the shipping position these washers [1] will be placed between the bridge and the shipping pad on the column so they don’t get lost.
When installing an APL look carefully for these washers [1] as you unbolt and raise the bridge. If you find washers [1] then move them to the upper pad on the same column when reinstalling the bridge.
This information will also be put on the APL Installation procedure.
