EC-1600
  1. Horizontal Mills
  2. 50-Taper
  3. EC-1600
EC-1600
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
CNC Horizontal Mill with 64" x 50" x 32" travels
The highly popular Haas EC Series HMCs offer large work cubes and a maximum part capacity of 10,000 lb, making them perfect solutions for your large-part machining requirements. Models are available with a 4th-axis rotary platter integrated into the T-slot table to provide access to four sides of a part or tombstone, or simultaneous 4th-axis machining.
  • Standard side-mount tool changer, 50+1 tools
  • 50-taper spindle with a 2-speed gearbox
  • Extra-large work envelope
  • 50" max part swing with integrated 4th axis (optional)
See Available Stock
Current Lead Time
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
  • 50+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
EC SERIES MACHINES
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Machine Info
    Travels S.A.E METRIC
    X Axis 64.00 in 1626 mm
    Y Axis 50.00 in 1270 mm
    Z Axis 32.00 in 813 mm
    Spindle Centerline to Table 11.97 in 304 mm
    Spindle S.A.E METRIC
    Max Rating 30.0 hp 22.4 kW
    Max Speed 7500 rpm 7500 rpm
    Max Torque 340.0 ft-lbf @ 700 rpm 460.0 Nm @ 700 rpm
    Drive System 2-Speed Gearbox 2-Speed Gearbox
    Taper CT or BT 50 CT or BT 50
    Table S.A.E METRIC
    Length 64.0 in 1626 mm
    Width 36.0 in 914 mm
    T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
    T-Slot Center Distance 4.92 in 125 mm
    Number of Std T-Slots 7 7
    Max Weight on Table (evenly distributed) 10000 lb 4536 kg
    Integrated 4th Axis (A Axis) S.A.E METRIC
    Table 64 in x 32 in 1626 mm x 813 mm
    Platter Diameter 30.00 in 762 mm
    Travel 360 ° 360 °
    Max Part Swing 50.0 in 1270 mm
    Max Weight on Platter 10000 lb 4536.0 kg
    Max Rating 5.0 hp 3.7 kW
    Rotational Torque (continuous) 2000 ft-lbf 2712 Nm
    Backlash 30 arc-sec 30 arc-sec
    Gear Ratio 500:1 500:1
    Brake Torque 4000 ft-lbf 5423 Nm
    Min Resolution 0.001 ° 0.001 °
    Indexing Accuracy ± 30 arc-sec ± 30 arc-sec
    Rapids on A 36 °/sec 36 °/sec
    Max Cutting A 36 °/sec 36 °/sec
    Spindle Centerline to Table 5.75 in 146 mm
    Feedrates S.A.E METRIC
    Max Cutting 500 ipm 12.7 m/min
    Rapids on X 600 ipm 15.2 m/min
    Rapids on Y 600 ipm 15.2 m/min
    Rapids on Z 600 ipm 15.2 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 4000 lbf 17793 N
    Max Thrust Y 8000 lbf 35586 N
    Max Thrust Z 8000 lbf 35586 N
    General S.A.E METRIC
    Coolant Capacity 95 gal 360 L
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 50+1 50+1
    Max Tool Diameter (full)** 4.0 in 102 mm
    Max Tool Diameter, Large (adjacent empty)** 10.0 in 254 mm
    Max Tool Length (from gage line) 20.00 in 508 mm
    Max Tool Weight 30.0 lb 13.6 kg
    Tool-to-Tool (avg) 8.00 s 8.00 s
    Chip-to-Chip (avg) 12.60 s 12.60 s
    Inline Air Hose 3/8 in 3/8 in
    Coupler (Air) 3/8 in 3/8 in
    Spindle Speed 7500 rpm 7500 rpm
    Spindle Power 30.0 hp 22.4 kW
    Domestic Pallet 192.0 in x 144.0 in x 136.0 in 488 cm x 366 cm x 346 cm
    Export Crate 192.0 in x 144.0 in x 137.0 in 488 cm x 366 cm x 348 cm
    Weight 30000 lb 13608.0 kg
    Export Crate w/Conveyor 127 in x 39 in x 86 in 323 cm x 100 cm x 219 cm
    Weight w/Conveyor 900 lb 409 kg
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    AVAILABLE OPTIONS
    VIDEOS
    CUSTOMER TESTIMONIALS
    RELATED PRODUCTS
    Standard Features
    • 7500-rpm Spindle
    • 50+1 Side-Mount Tool Changer, 50-Taper
    • Variable Flow Coolant
    • Chip Auger
    • Enclosure Exhaust System
    • 95-Gallon Coolant Tank
    • Chip Tray Filter Kit
    • Single-Stage Coolant Pump
    • Control Widescreen Monitor
    • Large Remote Jog Handle with Touchscreen Display
    • Ethernet Interface
    • CNC Control Cabinet Cooler
    • Power Surge Protection
    • Second Home Position
    • Advanced Tool Management
    • Media Display M-Code; M130
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    • Stainless Steel Way Covers
    • Phone Charging Stand
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    • Installation Guide
    • Layout Drawing
    • Torque Chart
    • Operator’s Manual
    • EC Series Flyer
    • Rotary Fit Chart
    VIDEOS
    The EC-1600 Horizontal Machining Center
    EC-1600 Customer Machine Installation
    HaasBuilt - EC-1600
    Horizontal Mill: A Quick Overview
    Whether you need a horizontal machining center for high-volume production and unattended operation or really big work cubes and maximum weight capacity, Haas has an HMC that should fit the bill. This video gives an overview of our pallet changing mills, large-frame HMCs, and five-axis horizontal mills.
    Haas Wireless Intuitive Probing System
    Haas EC-1600ZT-5AX
    Display Pictures and Videos on Your Haas Control Using M130
    Overton Industries
    “We have two EC-1600 machines. Those primarily work on the large components for our own equipment that we’re building for our customers. It could be things like side plates, console bases, or the front and back of the machine, which is the big support structure for our machines. The Haas machines allow us to create a setup that helps us get rid of chips, and being able to evacuate the chips allows us to machine the parts not only with a better quality, but also faster than we could with a vertical machine.”
    – Steve Overton, CEO
    CM Shredders
    CM Shredders of Sarasota, FL, manufactures industrial tire shredders, and uses a pair of Haas EC-1600 HMCs to machine the large-diameter knife holders that go into their machines. General manager Charles Astafan discusses how the EC-1600s easily handle the tight tolerances required for the shredder blades, and talks about the company’s 20+ year history with Haas.
    RELATED PRODUCTS
    LARGER WORK ENVELOPE
    Haas EC-1600ZT
    EC-1600ZT
    CNC Horizontal Mill with 64" x 50" x 40" travels
    • 50 Taper
    • 3 Axis
    • 7.5k RPM
        CNY ONLY
    Learn More Build & Price
    SMALLER WORK ENVELOPE
    Haas VF-840
    VF-8/40
    CNC Vertical Mill with 64" x 40" x 30" travels
    • 40 Taper
    • 3 Axis
    • 8.1k RPM
    • 30+1 Tool Capacity
        CNY ONLY
    Platter Diameter – Optional 4th Axis: 30" (762 mm)
    Max Part Swing, EC-1600: 50" (1270 mm)
    All VF-2 columns are machined on EC-1600s
    HAAS MACHINES MAKING HAAS MACHINES!
    Build & Price
    Get Started
    Need More Information?
