EC-1600ZT
  1. Horizontal Mills
  2. 50-Taper
  3. EC-1600ZT
EC-1600ZT
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
CNC Horizontal Mill with 64" x 50" x 40" travels
The highly popular Haas EC Series HMCs offer large work cubes and a maximum part capacity of 10,000 lb, making them perfect solutions for your large-part machining requirements. Models are available with a 4th-axis rotary platter integrated into the T-slot table to provide access to four sides of a part or tombstone, or simultaneous 4th-axis machining. The EC-1600ZT offers more Z-axis travel than the standard EC-1600
  • Extended Z-axis travel
  • Standard side-mount tool changer, 50+1 tools
  • 50-taper spindle with a 2-speed gearbox
  • Extra-large work envelope
  • 78" max part swing with integrated 4th axis (optional)
See Available Stock
Current Lead Time
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
  • 50+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
50-Taper, 120+1 SMTC, 4+1 Pallet Pool
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Machine Info
    • Rotary Fit Chart
    Travels S.A.E METRIC
    X Axis 64.00 in 1626 mm
    Y Axis 50.00 in 1270 mm
    Z Axis 40.00 in 1016 mm
    Spindle Centerline to Table 11.97 in 304 mm
    Spindle S.A.E METRIC
    Max Rating 30.0 hp 22.4 kW
    Max Speed 7500 rpm 7500 rpm
    Max Torque 340.0 ft-lbf @ 700 rpm 460.0 Nm @ 700 rpm
    Drive System 2-Speed Gearbox 2-Speed Gearbox
    Taper CT or BT 50 CT or BT 50
    Table S.A.E METRIC
    Length 64.0 in 1626 mm
    Width 36.0 in 914 mm
    T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
    T-Slot Center Distance 4.92 in 125 mm
    Number of Std T-Slots 7 7
    Max Weight on Table (evenly distributed) 10000 lb 4536 kg
    Integrated 4th Axis (A Axis) S.A.E METRIC
    Table 64 in x 32 in 1626 mm x 813 mm
    Platter Diameter 30.00 in 762 mm
    Travel 360 ° 360 °
    Max Part Swing 78.0 in 1981 mm
    Max Weight on Platter 10000 lb 4536.0 kg
    Max Rating 5.0 hp 3.7 kW
    Rotational Torque (continuous) 2000 ft-lbf 2712 Nm
    Backlash 30 arc-sec 30 arc-sec
    Gear Ratio 500:1 500:1
    Brake Torque 4000 ft-lbf 5423 Nm
    Min Resolution 0.001 ° 0.001 °
    Indexing Accuracy ± 30 arc-sec ± 30 arc-sec
    Repeatability 15 arc-sec 15 arc-sec
    Rapids on A 36 °/sec 36 °/sec
    Max Cutting A 36 °/sec 36 °/sec
    Spindle Centerline to Table 5.75 in 146 mm
    Feedrates S.A.E METRIC
    Max Cutting 500 ipm 12.7 m/min
    Rapids on X 600 ipm 15.2 m/min
    Rapids on Y 600 ipm 15.2 m/min
    Rapids on Z 600 ipm 15.2 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 4000 lbf 17793 N
    Max Thrust Y 8000 lbf 35586 N
    Max Thrust Z 8000 lbf 35586 N
    General S.A.E METRIC
    Coolant Capacity 95 gal 360 L
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 50+1 50+1
    Max Tool Diameter (full)** 4.0 in 102 mm
    Max Tool Diameter, Large (adjacent empty)** 10.0 in 254 mm
    Max Tool Length (from gage line) 20.00 in 508 mm
    Max Tool Weight 30.0 lb 13.6 kg
    Tool-to-Tool (avg) 8.00 s 8.00 s
    Chip-to-Chip (avg) 12.60 s 12.60 s
    Inline Air Hose 3/8 in 3/8 in
    Coupler (Air) 3/8 in 3/8 in
    Spindle Speed 7500 rpm 7500 rpm
    Spindle Power 30.0 hp 22.4 kW
    Domestic Pallet 192.0 in x 166.0 in x 136.0 in 488 cm x 422 cm x 346 cm
    Export Crate 192.0 in x 166.0 in x 140.0 in 488 cm x 422 cm x 356 cm
    Weight 29700 lb 13472.0 kg
    Weight, Export Crate 31,400 lb 14,243.0 kg
    Domestic Pallet w/70+1 SMTC 207.5 in x 163.0 in x 140.0 in 527 cm x 414 cm x 356 cm
    Weight w/70+1 SMTC 31,279 lb 14,188.0 kg
    Domestic Pallet w/Conveyor & 70+1 SMTC 207.5 in x 163.0 in x 140.0 in 527 cm x 414 cm x 356 cm
    Weight w/Conveyor & 70+1 SMTC 32,320 lb 14,660.0 kg
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    AVAILABLE OPTIONS
    VIDEOS
    CUSTOMER TESTIMONIALS
    RELATED PRODUCTS
    Standard Features
    • 7500-rpm Spindle
    • 50+1 Side-Mount Tool Changer, 50-Taper
    • Variable Flow Coolant
    • Chip Auger
    • Enclosure Exhaust System
    • 95-Gallon Coolant Tank
    • Chip Tray Filter Kit
    • Single-Stage Coolant Pump
    • Control Widescreen Monitor
    • Large Remote Jog Handle with Touchscreen Display
    • Ethernet Interface
    • CNC Control Cabinet Cooler
    • Power Surge Protection
    • Second Home Position
    • Advanced Tool Management
    • Media Display M-Code; M130
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    • Stainless Steel Way Covers
    • Phone Charging Stand
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    Available 4+1 Pallet Pool
    Our 4+1 pallet pool for the Haas EC-1600ZT HMC is the perfect solution for automated loading and unattended machining of large, heavy parts. It's also well suited for low-volume repeat jobs, where you want to keep the fixturing intact between runs.
    4-STATION
    • 3D Model w/Pallet Pool (ZIP)
    • Installation Guide
    • Layout Drawing
    • Torque Chart
    • Operator’s Manual
    • EC Series Flyer
    VIDEOS
    Horizontal Mill: A Quick Overview
    Whether you need a horizontal machining center for high-volume production and unattended operation or really big work cubes and maximum weight capacity, Haas has an HMC that should fit the bill. This video gives an overview of our pallet changing mills, large-frame HMCs, and five-axis horizontal mills.
    The Redesigned EC-1600
    The popular EC-1600 has received a host of improvements, making it better than ever, like a faster spindle and tool changer, more rigid castings, and new operator-convenience features.
    Wireless Intuitive Probing System
    With the Haas Wireless Intuitive Probing System (WIPS), you can set tool and work offsets in a fraction of the time. No more edge finders or slips of paper under the tool needed.
    The Haas EC-1600ZT-5AX
    We took our tried-and-true EC-1600ZT, and added 4th- and 5th-axis capabilities to create an HMC capable of full 5-axis machining on large parts.
    Display Pictures and Videos on Your Haas Control Using M130
    Mark shows off the powerful Haas M130 Media Display feature. By commanding an M130, you can display setup sheets, tool lists, work instructions, and even videos – all from within your program.
    Actron Engineering
    “The decision to buy an EC-1600ZT came about because we started getting some larger parts and that we felt we could hit from all four sides. We also felt that a lot of the fabrications we were doing required too much setup on the verticals, and we liked the ability to rotate on the C-axis to get all around the part to do different types of machining.”
    – John Staszewski, President, Actron Engineering
    Customer Spotlight - Straton Industries
    Straton Industries has been using Haas CNC machine tools for the last 5 years to machine parts for aerospace and space exploration. They started with a UMC-750 5-axis universal machining center, and have since added five more Haas machines, including two UMC-500SS 5-axis universal machining centers, two EC-1600ZT horizontal machining centers, and an ST-20Y turning center.
    RELATED PRODUCTS
    SMALLER WORK ENVELOPE
    Haas EC-1600
    EC-1600
    CNC Horizontal Mill with 64" x 50" x 32" travels
    • 50 Taper
    • 3 Axis
    • 7.5k RPM
        CNY ONLY
    Learn More Build & Price
    VMC w/ SMALLER WORK ENVELOPE
    Haas VF-840
    VF-8/40
    CNC Vertical Mill with 64" x 40" x 30" travels
    • 40 Taper
    • 3 Axis
    • 8.1k RPM
    • 30+1 Tool Capacity
        CNY ONLY
    Platter Diameter – Optional 4th Axis: 30" (762 mm)
    Max Part Swing, EC-1600ZT: 78" (1981 mm)
    All VF-2 columns are machined on EC-1600s
    HAAS MACHINES MAKING HAAS MACHINES!
    HA2TS EC-1600ZT POSITIVE FIT
    HA5C EC-1600ZT POSITIVE FIT
    HA5C2 EC-1600ZT POSITIVE FIT
    HA5C3 EC-1600ZT POSITIVE FIT
    HA5C4 EC-1600ZT POSITIVE FIT
    HA5CS EC-1600ZT POSITIVE FIT
    HRC160 EC-1600ZT POSITIVE FIT
    HRC210 EC-1600ZT POSITIVE FIT
    HRT160 EC-1600ZT POSITIVE FIT
    HRT160-2 EC-1600ZT POSITIVE FIT
    HRT160SP EC-1600ZT POSITIVE FIT
    HRT160SS EC-1600ZT POSITIVE FIT
    HRT210 EC-1600ZT POSITIVE FIT
    HRT210-2 EC-1600ZT POSITIVE FIT
    HRT210M EC-1600ZT POSITIVE FIT
    HRT210SP EC-1600ZT POSITIVE FIT
    HRT310 EC-1600ZT POSITIVE FIT
    HRT310SP EC-1600ZT POSITIVE FIT
    HRT450 EC-1600ZT POSITIVE FIT
    TH450 EC-1600ZT POSITIVE FIT
    HRTA5 EC-1600ZT POSITIVE FIT
    HRTA6 EC-1600ZT POSITIVE FIT
    T5C EC-1600ZT POSITIVE FIT
    T5C2 EC-1600ZT POSITIVE FIT
    T5C3 EC-1600ZT POSITIVE FIT
    T5C4 EC-1600ZT POSITIVE FIT
    TR160 EC-1600ZT POSITIVE FIT
    TR160-2 EC-1600ZT POSITIVE FIT
    TR200Y EC-1600ZT POSITIVE FIT
    TR210 EC-1600ZT POSITIVE FIT
    TR310 EC-1600ZT POSITIVE FIT
    TRT100 EC-1600ZT POSITIVE FIT
    TRT160 EC-1600ZT POSITIVE FIT
    TRT210 EC-1600ZT POSITIVE FIT
    TRT70 EC-1600ZT POSITIVE FIT
    HRT210HT EC-1600ZT POSITIVE FIT
    TH240 EC-1600ZT POSITIVE FIT
    HA5C2-T EC-1600ZT POSITIVE FIT
    HRT210SS EC-1600ZT POSITIVE FIT
    HA5C-T EC-1600ZT POSITIVE FIT
    HA5C3-T EC-1600ZT POSITIVE FIT
    HA5C4-T EC-1600ZT POSITIVE FIT
    TRT310 EC-1600ZT POSITIVE FIT
    HRT310SS EC-1600ZT POSITIVE FIT
    HRT630 EC-1600ZT POSITIVE FIT
    LT350 EC-1600ZT POSITIVE FIT
    HRT210VM EC-1600ZT POSITIVE FIT
    LT260 EC-1600ZT POSITIVE FIT
    HRT200HS EC-1600ZT POSITIVE FIT
    HQDA5 EC-1600ZT POSITIVE FIT
    TR500SS EC-1600ZT ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HQDA6 EC-1600ZT POSITIVE FIT
    HRT210S EC-1600ZT POSITIVE FIT
    HDD255 EC-1600ZT ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    Build & Price
    Get Started
    Need More Information?
