EC-1600ZT
PRE-INSTALLATION [GUIDE]
EC-1600ZT
    CNY ONLY
CNC Horizontal Mill with 64" x 50" x 40" travels
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
  • 30+1 Tool Capacity
  • Layout Drawing
  • Lifting Instructions
  • Additional Resources
Pre-Installation Checklist
STEP-BY-STEP INSTALLATION GUIDE
PALLET POOL INSTALLATION GUIDE
Pallet Pool Pre-Installation
The EC‑1600ZT machine must be fully placed and installed by the HFO prior to starting the pallet pool installation. Pallet pool installation is a separate process from the machine install.
Due to this sequencing, rigging personnel may need to return after the machine installation is completed. Estimated pallet pool installation time: 5–6 days
Note: This duration does not include machine installation
  • Third-party riggers and forklift support are typically required for 1–2 days during pallet pool installation.
  • Forklift is required for initial placement only. (Pallet Pool Main Base and Load Station installation).
Coordinate separate scheduling for:
  • Machine installation
  • Pallet pool rigging
Ensure rigging availability after machine install is complete
Verify site readiness before scheduling pallet pool installation
Foundation
You must put your machine on a solid and stable concrete foundation. The standard 6" (150 mm) concrete floor in industrial buildings is usually sufficient. However, Large-Frame machines may require a 12" (300 mm) concrete foundation. The EC-1600 must be on a 12" (300 mm) foundation. Refer to these specifications:
  • Continuous slab
  • Note: The EC-1600 series and UMC-1600-H must be on a 12" (300 mm) foundation.
☑ Anchoring
This machine requires an anchoring kit. Click here to view anchoring kits for your machine
☑ Machine Placement
☑ Optional Component Location
  • External Transformers.
Layout Drawing
Download Machine Layout Drawing (PDF)
Download Pallet Pool Layout Drawing (PDF)
Read these instructions in their entirety before attempting to lift the machine.
WARNING:
IT IS IMPERATIVE THAT PREPARATION AND LIFTING OF THE MACHINE BE PERFORMED BY PROFESSIONAL RIGGERS. THESE INSTRUCTIONS ARE FOR REFERENCE PURPOSES ONLY.
IMPORTANT: Most – but not all* – Haas machines may be lifted by overhead crane for positioning and installation. Depending on the model, your new Haas machine may have built-in lifting provisions, or may require a lifting kit, available through your local Haas Factory Outlet (HFO), that includes required lifting brackets and hardware.
Refer to the lifting placard on the rear of the machine to locate all critical lifting points.
Specialized equipment is necessary to ensure that the machine is secure and level during lifting. When lifting the machine, slowly lift until all chains are taut, then lift the machine, making sure it stays balanced. Remove lifting brackets and hardware, if installed, before machine operation, unless otherwise noted. It is the customer’s responsibility to supply all chains and spreader bars required to properly lift the machine. Contact your local HFO for more information. Retain any supplied lifting brackets and hardware, and store them in a safe place for future use. Use only Haas-supplied lifting hardware, if required.
Refer to the lifting placard on the rear of the machine for model-specific lifting information. Attach the lifting bracket, if required, and chains as shown. Make sure that the chains do not contact the sheet metal enclosure or electrical cables. Note the use of spreader bars and lumber. Haas Automation, Inc., does not provide spreader bars or lumber.
*GR, GM, TL, CM, and CL models are not suitable for overhead lifting. They must be lifted by forklift.
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 7500 rpm 7500 rpm
Drive System 2-Speed Gearbox 2-Speed Gearbox
Spindle Power 30.0 hp 22.4 kW
Domestic Pallet 192.0 in x 166.0 in x 136.0 in 488 cm x 422 cm x 346 cm
Export Crate 192.0 in x 166.0 in x 140.0 in 488 cm x 422 cm x 356 cm
Weight 29700 lb 13472.0 kg
Weight, Export Crate 31,400 lb 14,243.0 kg
Domestic Pallet w/70+1 SMTC 207.5 in x 163.0 in x 140.0 in 527 cm x 414 cm x 356 cm
Weight w/70+1 SMTC 31,279 lb 14,188.0 kg
Domestic Pallet w/Conveyor & 70+1 SMTC 207.5 in x 163.0 in x 140.0 in 527 cm x 414 cm x 356 cm
Weight w/Conveyor & 70+1 SMTC 32,320 lb 14,660.0 kg
Optional Spindles
SPINDLE SPINDLE DRIVE PEAK (HP/KW) PEAK TORQUE (ft-lbs/Nm) INPUT AC VOLTAGE FULL LOAD AMPS
7.5K-rpm High-Performace Spindle Gearbox 60/44.7 392/531
220 (3 Phase)
440* (3 Phase)
105
53
10K-rpm High-Performace Spindle Gearbox 60/44.7 392/531
220 (3 Phase)
440* (3 Phase)
105
53
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines CL-1, and CM-1. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
ATTENTION! Optional high-performance spindles have a higher power requirement than the standard spindle. Verify the power requirement before running power for your machine.
Caution:
    • soluble oil coolant
    • semi-synthetic coolant
    • synthetic coolant
General
  • Refer to the Machine Layout Drawing for the location of the machine's electrical input.
440 V Power *
  • Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines, CL-1, and CM-1.
Ground
Three-Phase Power
Single-Phase Power
Wire Size
Service Breaker
Phase Converters
  • Anchoring Instructions
  • Video Library
  • Operator’s Manual
  • Service
