EC-1600 - Installation - NGC
Service Home How To Procedures EC-1600 - Installation - NGC
Recently Updated Last updated: 02/10/2026
- Jump to Section - 1. Machine Compatibility 2. Introduction (1 step) 3. Leveling Screws Hardware 4. Removal of Rust Inhibitor 5. Air Connection 6. Electrical Connections 7. Remove Shipment Blocking (3 steps) 8. Panel Extension (2 steps) 9. Leveling (5 steps) 10. Install Middle Base Support Wedge (1 step) 11. Lubrication Verification (2 steps) 12. Rear Chip Auger (2 steps) 13. Option Installation Guides Back to Top
This procedure applies to the EC-1600 and EC-1600ZT machines that were built after October, 2019.
Use these numbers to identify which foot to adjust.
Prerequisites:
Adjust each leveling screw until the base is 4" (10 cm) above the floor (3" (76 mm) leveling pad height plus 1" (25 mm) of screw below the bottom of the pad).
 Note: The condition of the foundation may require different heights at some leveling screws to make the machine level.
Tools Required:
  • CNC Dual Leveling Tool (P/N T-2181)
  • 6" (15 cm) granite square
Note: The washers [1] and nuts [2] are installed during shipping and should be saved for installation and not be discarded.
Note: The washer orientation [3] is important.  The conical part of the washer should be against the casting,  see illustration.
Air Connection
Connect the air supply at the lube panel.
 Note: For air requirements refer to the decal that is located on the lube cabinet door.
Follow the Air Gun and Hose Installation procedure to install or replace the Air Gun.
 Note: Some installation kits will come with a spare air gun assembly.
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
Initial Control Inspection
Danger: At this point, there should be no electrical connection to the machine. Electrical panel must be closed and secured. When main switch is on, there is HIGH VOLTAGE throughout the electrical panel (including the circuit boards and logic circuits) and some components operate at high temperatures. Therefore, exercise extreme caution when working in the panel.
  • Set the main breaker switch at the upper right of the electrical panel on the back of the machine to OFF.
  • Using a screwdriver, unlock the two latches on the panel door, unlock the cabinet with the key and open the door.
  • Take sufficient time to check all the components and connectors associated with the circuit boards. Look for any cables that have become disconnected, look for any signs damage and loose parts in the bottom of the panel box. If there are any signs that the machine was mishandled, call the factory before proceeding.
1-Phase Machines: Insert each power lead into the wire cover.  Connect the two power leads to L1 and L3 terminals on top of the main circuit breaker.
3-Phase Machines: Insert each power lead into the wire cover.  Connect the three power leads to L1, L2 and L3 terminals on top of the main circuit breaker.
Connect the separate ground line to the ground bus to the left of the terminals.
For 3-phase machines, check to see what type of power configuration is supplying the machine. Take voltage measurements of each power lead to ground line. Then refer to RD0084 - Input Power Configurations to determine which power lead should be connected to the L1 terminal based of the voltage readings and power configuration.
Refer to Haas Main Circuit Breaker - Torque Specifications for what value to torque the circuit breaker power leads.
 Note: Make sure that the leads actually go into the terminal-block clamps . (A poor connection will cause the machine to run intermittently or have other problems, such as servo overloads.) To check, simply pull on the wires after the screws are tightened.
After the line voltage is connected to the machine, make sure that main circuit breaker (at top-right of rear cabinet) is OFF . Remove the Lockout / Tagout and Turn ON the power at the source. Using a digital voltmeter and appropriate safety procedures:
1-Phase Machines: Measure the AC voltage across L1 & L3 at the main circuit breaker.  The AC voltage must be between 220 - 250 volts .
Note: Lower or higher than this voltage can generate low/high voltage alarms.
3-Phase Machines : Measure the AC voltage between all three pair phases at the main circuit breaker.
The AC voltage must be between 195 and 260 volts (360 and 480 volts for high voltage option).
SMinimill - Reboot: The AC voltage must be between 198 and 242 volts for machines without a high voltage transformer.  Refer to the Minimill/SMinimill - Identification document.
 Note: Wide voltage fluctuations are common in many industrial areas; minimum and maximum voltage supplied to a machine while it is in operation must be known. U.S. National Electrical Code specifies that machines should operate with a variation of +5% to -5% around an average supply voltage. If problems with line voltage occur, or low line voltage is suspected, an external transformer may be used. If you suspect voltage problems, voltage should be checked every hour or two during a typical day to be sure it does not fluctuate more than +5% or -5% from an average.
Important: With the main circuit breaker turned OFF.
Check the transformer taps at the bottom-right corner of the rear cabinet.
1-Phase Machines: The input voltage cable must be moved to the connector which corresponds to the average voltage measured in the above step.
3-Phase Machines:  The input voltage cables labeled 74, 75, and 76 must be moved to the terminal block triple which corresponds to the average voltage measured in the above step.
Transformer T5 supplies 24VAC used to power the main contactor. There are two versions of this transformer for use on a 240 and 400V machines. The 240V transformer has two input connectors located about two inches from the transformer, which allow it to be connected to either 180-220V or 221-240V.
Users that have 220V-240V RMS input power should use the connector labeled 221-240V, while users with 190-220V input power should use the connector labeled 180-220V. Failure to use the correct input connector will result in either overheating of the main contactor or failure to reliably engage the main contactor.
The 480V (option) T5 transformer has three input connectors, labeled 340-380V, 381-440V and 441-480V.
Users with 340-380V 50/60Hz power should use the 340-380V connector while users with 380V-440V 50/60Hz power should use the 381-440V connector.
Important: Set the main circuit breaker to ON. Check for evidence of problems, such as the smell of overheating components or smoke. If such problems are indicated, immediately set the main circuit breaker to OFF and call the factory before proceeding.
After the power is on, measure the voltage across the bottom terminals on the main circuit breaker. It should be the same as the measurements where the input power connects to the main breaker. If there are any problems, check the wiring.
Apply power to the control by pressing the Power-On switch on the front panel.
Check the DC Voltage and AC Line Voltage gauges in Diagnostics. The DC Voltage gauge must read between 310 - 360V. The AC Line Voltage must be between 90 and 105 percent. If the voltage is outside these limits, turn off the power and recheck steps 2 and 3. If the voltage is still outside these limits, call the factory.
Electrical power must be phased properly to avoid damage to your equipment. The Power Supply Assembly PC board incorporates a "Phase Detect" circuit with neon indicators. When the orange neon is lit (NE5), the phasing is incorrect. If the green neon is lit (NE6), the phasing is correct. If both neon indicators are lit, you have a loose wire; check the connections. Adjust phasing by setting the source power to off and then swapping L1 and L2 of the incoming power lines at the main circuit breaker.
Danger: ALL POWER TO CNC MUST BE TURNED OFF LOCKOUT-TAGOUT AT THE SOURCE PRIOR TO ADJUSTING PHASING. ALWAYS DOUBLE CHECK THE INCOMING LINES WITH AN AC VOLTAGE DETECTOR.
Turn off the power and set the main circuit breaker to OFF. Close the door, lock the latches, and turn the power back on.
Remove the key from the control cabinet and give it to the shop manager.
Activation
When the machine is properly placed and connected to both air and electrical power, it is ready for final installation (removing shipping blocks, leveling, spindle sweep, etc.) and software activation. The HFO service technician does this. Contact the local HFO to schedule the work.
IMPORTANT:  Machines equipped with motion sensors must be rough‑leveled before attempting to arm the motion sensor.  For detailed instructions, refer to Service Notification - SA0007.  Access to this document is restricted to Haas Factory Outlet personnel.
  • Remove control blocking bracket.
  • Remove all three door brackets.
  • There are 2 on the front loading doors keeping them closed (shown) and one keeping the operator door open.
  • Do not attempt to open/close any doors without removing blocking. Damage may occur.
  • Remove rear enclosure panel
  • Inside the column, find 2 blocking pins bolted in place with 1" bolts. [2]
  • Remove the bolts and blocking pins
  • Remove X-axis table blocking bracket [1]
Note: There is no shipping bracket for the Y-axis. Spindle head jogged to the end of travel .
Panel Extension
EC-1600/ZT with 50 or 70 pocket Tool Changers.
 Warning: If panel is not extended the tool changer/tools can contact the sheet metal and cause damage.
Locate the back panel [1] near the tool carousel. Remove any sheet metal [2] needed to gain access.
Note: The back panel [1] should be marked with a decal [3] indicating the extension step.
Remove all screws [4], except the bottom screw [5] on either side, holding the panel to the enclosure.
 Note: Only the right bottom screw [5] is shown. The left bottom screw is in the same position on the opposite side of the panel.
Loosen the bottom two screws [5] but leave them installed. The panel will pivot about them.
Extend the back panel [1] away from the tool carousel until the second set of holes [2, 3] align with the holes on the panel.
Install remaining screws and tighten the bottom screws [4] on either side of the panel.
Install sheet metal [5].
Leveling
Remove the Z-Axis roll.
Make sure the floor of the column is clean.
Put a 6" (15 cm) granite square inside the rear of the column.
Put the CNC dual leveling tool [1] onto the square parallel to the X Axis.
Jog the Z Axis in the negative (-) direction to the end of travel.
Record the position of the bubble in the level.
Jog the Z Axis in the positive (+) direction to the end of travel.
Compare the two positions.
Adjust the 1,2 (rear) feet [2] or the 6, 7, and 8 (front) feet until the bubble stays in the center of the level at each end of travel.
Remove the Z-Axis pitch.
Put the CNC dual leveling tool [1] onto the square parallel to the Z Axis.
Adjust the 1, 8, 9, 10, and 11 (left-hand side) feet or the 2, 3, 4, 5 and 6 (right-hand side) feet [2] until the bubble stays in the center of the level at each end of travel.
Level the X Axis.
Zero return all Axes.
Make sure the rotary table is clean.
Put the CNC dual leveling tool on the rotary table. Make sure the long side is parallel to X-axis.
Adjust the 1, 11, 10, 9 and 8 (left-hand side) feet or the 2, 3, 4, 5 and 6 (right-hand side) feet [1] until the bubble is in the center of the level.
Put the level perpendicular to the X-axis.
Adjust the 1 and 2 (rear) feet [2] or the 6, 7 and 8 (front) feet until the bubble is in the center of the level.
Level the Z Axis.
Put a granite square [1] onto the table adjacent to the spindle.
Put an indicator into the spindle.
Put the stylus against the top of the square. Set the indicator to 0.
Jog the A Axis to -180 degrees.
Jog the Z Axis until the stylus touches the block.
If the indicator reading is less than 0.0005", no adjustment is necessary.
If the indicator reading is more than 0.0005", adjust the 6, 7, and 8 (front) feet [2].
Once the machine is leveled, install and tighten the jam nuts on the leveling screws.
 NOTE: Machine has to be leveled 3" above the floor. The support wedge block height adjustment range is 2-3/4" - 3-1/8".  You can use a suitable steel plate under the wedge block if machine is leveled more than 3" above the floor.
Move the Z axis to the home position.
Slide the support wedge [1] under the support feature [2] on the bottom of the base.
With the Z axis all the way back, tighten the support wedge screw [3] until the top of the wedge makes contact with the support feature on the bottom of the base.
The wedge will support the middle of the base as the Z axis moves towards the table.
Run the spindle run-in program.
 Note: For 10K spindles and above use a balanced tool holder
Examine the sight glass, make sure the correct number of drops are fall through the sight glass.
Examine the fittings [1,2] on top of the oil pump tank.
The oil collects on top of the oil pump tank [3] either behind or in front of the sight glass bracket, underneath the leaking fitting.
Tighten any leaking fittings.
Go to the Maintenance tab.
Press [F2] to cycle an axis lubrication test.
Inspect the gauge on the lubrication system.  Make sure it holds pressure.
Rear Chip Auger
Remove the cover from the auger-motor assembly.
Pull the augers [1] out of the EC-1600.
Do this until they extend more than the end of the machine.
Connect the augers to the auger-motor assembly [2].
Attach the cover for the auger-motor assembly.
Attach the cover [1] for the rear pan to the top of the auger-motor assembly.
Apply construction sealant (Sikaflex) to the surfaces of the auger-motor assembly that touch the enclosure.
Attach the auger-motor assembly [2] to the machine.
Put the auger power cable into the bottom of control cabinet.
Connect the power cable [3] to P24 on the I/O PCB.
Verify and test that all the options have been properly installed.
Remote Jog Handle - Touch Large (RJH-XL) - Installation
Wi-Fi Camera Option Installation
VMC Convenience Package
Auxilary Coolant Filter
Accesory Tooling Block
Anchoring Instructions
CABCOOL installation
Pulsejet Installation
HAAS Oil Skimmer
Table work light
Auto Air Gun
