  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
115V Table Work Light - Installation - AD0475
Service Home How To Procedures 115V Table Work Light - Installation - AD0475
Recently Updated Last updated: 02/08/2021
AD0475
This procedure tells you how to install the table work light on the following machines:
  • VF 6-12
  • UMC 500-1000
Prerequisites
Parts Required:
  • 93-1000292 WORK TABLE LIGHT
  • 93-1000487 WORK TABLE LIGHT UMC 750 PRE-RBT
  • 93-1000488 WORK TABLE LIGHT UMC
  • 93-1000489 WORK TABLE LIGHT LRG VF
Assemble work light
Using the components given in the kit assemble the work light as shown.
The bracket [1] will need to be changed to the provided bracket before proceeding with the install.
Installation: VF-6 to 9
Push POWER OFF.
Set the main circuit breaker to the OFF position.
For the VF 6-9 the worklight will be placed in the location denoted as [1].
Start routing the cable to the top of the machine [2], use the wire channels given in the kit to neatly tuck away the cable on the front face of the machine.
Once above the machine connect the extension so that the work light cable will now reach the connection area denoted as [4].
Disconnect the inner LED cable and add the splitter to the connection area [4]. Connect the work light cable and reconnect the inner LED light cable.
Conceal the excess cable under the cable cover sheet metal [3] as best you can.
Use zip ties wherever necessary to keep cable in place.
Actuate the light switch on the side of the controller to test that the work light turns on.
Installation: VF-10/11
Push POWER OFF.
For the VF 10 the worklight will be placed in the location denoted as [1].
Once above the machine connect the extension so that the work light cable will now reach the connection area denoted as [3].
The work light cable may be long enough to meet the junction, if not use the extension and neatly ziptie excess together.
Disconnect the inner LED cable and add the splitter to the connection area [3]. Connect the work light cable and reconnect the inner LED light cable.
Installation: VF-12
Push POWER OFF.
Installation: UMC
Push POWER OFF.
For the UMC line the worklight will be placed in the location denoted as [1].
Start routing the cable to the top of the machine by placing the cable on the side of the machine right next to the edge where the tool holders would be placed [2]. Use the wire channels given in the kit to neatly tuck away the cable on the front face of the machine.
Connect the extension in the area specified [3] so that it may be routed into the tool changer area.
UMC-750 Pre-Reboot
The table is on the right side of the machine. Mount the work light in location [1] and use the wire channels to hide the wire on the front face of the machine. Three extensions will be used to route the wire around the top spindle cover [2] which is not picutred, and into the tool changer enclosure.
Follow the cable [4] to find the inner LED cable connection and unplug it.
NOTE you may need to remove the sheet metal [5] on the inside of the machine to reach the cable connection.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
