Cabinet Cooler - Installation - AD0071
Service Home How To Procedures Cabinet Cooler - Installation - AD0071
22.1 Cabinet Cooler - Installation
Recently Updated Last updated: 02/18/2021
AD0071
Revision B - 06/2026
The Cabinet Cooler features include:
  • Automatically operates when the machine operates.
  • An air conditioning unit to keep the control cabinet cool at all times.
  • Maintains a control cabinet temperature 20°F (7°C) cooler than the operating temperature.
Machine Compatibility
You can install the Cabinet Cooler on all Haas CNC machines built after June, 2007 with a vector drive.
Important: The Cabinet Cooler cannot be installed on these machines:
  • TM/TL/MM/CM/CL/OM/OL
Power Requirements:
For 230VAC machines a 32-5830x Main Transformer is required.
This procedure applies to the following service kits:
  • 93-30-11330A CABCOOL MECH REPLACEMENT KIT SVC
  • 93-1000286 CONTROL CABINET COOLER
  • 93-1000392 UMC-1000PP CABCOOL FIELD INSTALL KIT
  • 93-1000509 CABCOOL MECH KIT EC-1600 FIELD INSTALL
Note: Refer to EC-1600 Installation for the correct installation of the EC-1600 Cabinet Cooler.
To replace a Cabinet Cooler on a machine that already has one, go to Step 2.
Push [POWER OFF]. Set the main circuit breaker to the [OFF] position.
Caution: When you touch electronic components, use an electrostatic discharge strap.
Remove the door [2] for the control cabinet.
Use a drill with a size 45 (0.082") drill bit [1] to remove these parts:
  • Serial number plate.
  • Machine lift instructions plate.
Use a rivet gun [3] and (8) RIVETS [E] to install the plates onto the new CABCOOL DOOR [C].
Attach the CABCOOL DOOR [C] onto the control cabinet for decal placement.
IMPORTANT: Adhere decals provided in the kit to the new Control Cabinet Door. Use previously installed door as reference.
Put the power cable through the hole in the control cabinet door.
Place the bottom part of the CABCOOL [1] on the open section of the control cabinet door.
Note: The intake filter for the CABCOOL [1] must always be on the bottom.
Push the top part of the CABCOOL [1] in. Make sure the clip [2] latches onto the door.
Attach the CABCOOL [1] to the control cabinet door. Use the (8) SCREWS [3].
Electrical Installation
Updated
Install the cabcool / coolant chiller power supply [1] onto the main transformer using the machine screws [2], lock washers [3]. and washers [4].
IMPORTANT: If fitted with the ECO Mode Plus option orient the mounting bolts as shown in the image. If not, use the alternate holes on the cabcool / coolant chiller power supply [1].
Remove the sheet metal cover [1] from the main transformer.
Remove the red, white, and black power cables from the terminal block .
Install the red, white, and black power cables from the cabcool / coolant chiller power supply onto the terminal block.
Reinstall the removed red, white, and black power cables.
Reinstall the sheet metal cover [1].
Remove the main wire cover.
Route the power cable over the Amplifier fan bracket [1].
Plug power cable into the power supply.
Connect the power cable to the left outlet of the bracket [2] "Labeled CABCOOL".
Install the main wire cover.
Attach the CABCOOL DOOR [C] onto the control cabinet.
 IMPORTANT: Adhere decals to the new Control Cabinet Door. Use previously installed door as reference.
Install the door making sure the bolt hinge [2] is installed.
Push the top part of the CABCOOL [1] in. Make sure the clip latches onto the door.
Attach the CABCOOL MECH KIT [1] to the control cabinet door. Use the (8) SCREWS [2].
EC - 1600 Electrical Installation
Updated
Put the power cable [1] for the CABCOOL [A] through the cable channels.
Use the CLAMPS [D] to secure the cable.
Cabinet Cooler Test
Connect the cable to the right outlet labeled "COOLANT CHILLER".
NOTE:  This outlet always has power, it will be used to test the cabcool.
Push the [RESET] button on the cabinet cooler power cable to turn it on.
Make sure the CABCOOL blows cold air.
Push the TEST button on the power cable to turn it off.
Connect the power cable to the left outlet of the receptacle [1] "Labeled CABCOOL".
Push the RESET button on the power cable again.
Note: The outlet [1] labeled "CABCOOL" is thermostat controlled and will only provide power to the CABCOOL [A] unit when the temperature inside the control reaches approximately 100 F (38C).
Dual Spindle Lathes
If you are installing a Cabcool on a dual spindle lathe you might run an interference issue as seen on the images on the left side. Contact Haas support for the extension, 79-0300 PWR EXT CORD [1], that will take care of this issue.
