Convenience Package - Installation - Mill - AD0327
Service Home How To Procedures Convenience Package - Installation - Mill - AD0327
Recently Updated Last updated: 06/04/2026
Revision 1
AD0327
Revision A - 06/2026
- Jump to Section - 1. Introduction 2. Convenience Package - Installation - Mill (3 steps) 3. Swap Drawer Tray (2 steps) 4. Spindle Wiper (1 step) Back to Top
This procedure tells you how to install the mill Convenience Package. The Convenience Package comes in a box inside the mill enclosure. Install the Convenience Package during the mill installation. This procedure is for these kits:
  1. Convenience Package 30-taper
  2. Convenience Package 40-taper
  3. Convenience Package 50-taper
Updated
This procedure is applicable to several different kits. You use only (1) of the kits from this list based on the machine model:
  • 30-12135D - CONVENIENCE PKG 30T BT MED VF
  • 30-12136C - CONVENIENCE PKG 30T BT SML VF
  • 30-12287C - CONVENIENCE PKG 30T BT DT
  • 30-12290C - CONVENIENCE PKG 30T BT LRG VF
  • 30-12291C - CONVENIENCE PKG 40T BT LRG VF
  • 30-12292C - CONVENIENCE PKG 40T CT LRG VF
  • 30-12293C - CONVENIENCE PKG 50T BT/CT EC-1600/LRG VF
  • 30-12432C - CONVENIENCE PKG HSK-A 63 19" WIDE
  • 30-12476C - CONVENIENCE PKG HSK-A 63 L VF
  • 30-12477C - CONVENIENCE PKG HSK-A 63 MED VF
  • 30-12478C - CONVENIENCE PKG HSK-A 63 SML VF
  • 30-13557A - CONVENIENCE PKG 20T CM
  • 30-4735F -  CONVENIENCE PKG 40T CT MED VF
  • 30-4737F -  CONVENIENCE PKG 50T BT/CT MED VF
  • 30-5393F -  CONVENIENCE PKG 40T BT MED VF
  • 30-4733E - CONVENIENCE PKG 40T CT SML VF
  • 30-5392E - CONVENIENCE PKG 40T BT SML VF
  • 30-12288C - CONVENIENCE PKG 40T BT DM/MM/EC/UMC/VC
  • 30-12289C - CONVENIENCE PKG 40T CT DM/MM/EC/UMC/VC
  • 93-1000337 - CONVENIENCE PKG 40T CT SM
  • 93-1000336 - CONVENIENCE PKG 40T BT SM
  • 93-1000335 - CONVENIENCE PKG 40T CT DM/MM/EC/UMC
  • 93-1000334 - CONVENIENCE PKG 40T BT DM/MM/EC/UMC/VC
  • 93-1001329 -  CONVENIENCE PACKAGE KIT CT POCKET MILL
  • 93-1001330 - CONVENIENCE PACKAGE KIT BT POCKET MILL
Note: This procedure is compatible for all kits updated after June 2020.
Connect the writing table [1] to the bottom shelf [2]. Use (4) 1/4-20 Flanged Button Head Cap Screws (FBHCS) [3].
Install the writing table [1] and bottom shelf [2] to the enclosure [3]. Use (8) 5/16-18 Button Head Cap Screws (BHCS) [4].
IMPORTANT: FOR DC-1 AND DC-2 MACHINES - Check the 8 BHCS fasteners [4] for blue loctite. Add a drop of blue loctite if needed before mounting the writing table to the machine enclosure.
Install the tool vise [1]. Use (4) 1/4-20 Socket Head Cap Screws (SHCS) [2] and (4) washers.
IMPORTANT: FOR DC-1 AND DC-2 MACHINES - If there is an insufficient amount of blue loctite on the 4 SHCS [2] add a drop of blue loctite before mounting the tool vise [1] to the side of the enclosure.
Install the tool holder tray [3]. Use (4) 5/16-18 BHCS [4] to mount the tray to the enclosure [5].
IMPORTANT: FOR DC-1 AND DC-2 MACHINES - Check the 4 BHCS [4] for blue loctite. Add a drop if needed before mounting the tool holder tray to the enclosure [5].
Swap Drawer Tray
The convenience kits listed in the introduction and older convenience packages that have the upgraded Writing Table detailed in the section above, can swap out the standard tray [1] in drawer with the following options:
09-0171 [2]: Tool Organizer Tray
09-0172 [3]: ER/5C Collet Holder
To replace the standard tray, remove the 4 FBHCS [1] and the 2 BHCS [3] located at the front of the tray with the drawer fully extended so that you can remove the tray [2] from the drawer.
Fasten the new organizer option to the drawer [1] using the same 4 FBHCS [2] and BHCS [3] from the previous step.
NOTE: The organizer option pictured is the Collet Holder. The Tool Organizer option is installed the same way.
Spindle Wiper
Spindle wipers are used to clean out the spindle.
Hold the spindle wiper [1] by the handle to insert and twist it in the spindle [2] to clean it out.
