    2. Español - España
    3. Español - México
    13. Постсоветский
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • Haas-Tooling-Home-TEST
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    2. Español - España
    3. Español - México
    13. Постсоветский
Search
Remote Jog Handle - Touch Large (RJH-XL) - Installation - AD0533
Service Home How To Procedures Remote Jog Handle - Touch Large (RJH-XL) - Installation - AD0533
Recently Updated Last updated: 02/01/2021
Revision 1
AD0533
This service kit can be used to install the RJH-XL on compatible machines or to replace the RJH-Touch with an RJH-XL.
Minimum Requirements:
Next Generation Control:
  • Software version 100.21.000.1120 and higher
  • 34-4510 SKBIF FOR NGC W/ RJH-C/VID CCA
  • SKBIF firmware 6.6 and higher
  • RJH firmware RA.03.06 and higher
  • Load the latest configuration files to enable the RJH-XL.
Note: Use this procedure to update the SKBIF and RJH firmware: SKBIF PCB / RJH Firmware Update - NGC
This document applies to the following parts:
  • 93-1000610: REMOTE JOG HANDLE TOUCH LCD (RJH-XL)
  • 32-0929:    RJH TOUCHSCREEN 5IN, HAND UNIT PKGD
Replacement
Follow thse steps if replacing a RJH-Touch with a RJH-XL
Remove the jumpers [1] on the SKBIF from the horizontal position and replace them in the vertical position.
WARNING: By not putting the jumpers in the vertical position, E-STOP functionality on the RJH-XL is disabled and the machine is considered unsafe.  Jumpers MUST be inserted vertically.
Remove the RJH-Touch [1] from the RJ12 COIL CORD [2] and connect the cord to the RJH-XL [3].
RJH-XL Wiring Installation
Free Hanging Thin Pendant or Thick Pendant with RJH-C Mounting [1].
1. Remove the back cover of the pendant.
2. Remove any plugs or screws at the RJH mounting location.
3. Wire the 6’ RJ12 cord through the 1/2” hole in the pendant and connect to P9 on the SKBIF.
4. Install the end of the 6’ RJ12 cable in the RJH Holster.
5. Attach the RJH Holster [2] to the pendant, storage cabinet or adapter bracket using three BHCS 10-32 x 1/2 screws.
The jumpers [1] on the SKBIF need to be removed from the horizontal position and replaced in the vertical position.
RJH-XL Hand Unit Installation
The holster [1] for the RJH-XL is on the left side of the storage cabinet [2] (as shown).
If the machine has no storage cabinet, the holster is on the right side of the pendant [3].
Connect one end of the RJ12 COIL CORD [D] to the receptacle on the bottom of the holster.
Connect the other end to the receptacle on the bottom of the RJH-XL [A].
Hang up the RJH-XL.
Reassemble the control pendant.
Plug any unused holes.
RJH-XL - Operation
Refer to the Mill Interactive Operator's Manual for Remote Jog Handle XL Operation information.
Verification
When taking the RJH-XL off the holster, the Remote Jog icon [1] should pop up on the bottom of the screen.
Then, push the [E-STOP] on the RJH-XL and make sure the E-Stop icon [2] pops up on the screen to ensure the remote e-stop works correctly.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
