SKBIF PCB / RJH Firmware Update - NGC
Service Home How To Procedures SKBIF PCB / RJH Firmware Update - NGC
Recently Updated Last updated: 05/16/2023
SKBIF PCB and RJH Compatibility
This procedure tells you how to update the SKBIF PCB and RJH firmware on a Next Generation Control.
Note: Always create a backup of the machine before you update the SKBIF PCB  or RJH firmware. Refer to Next Generation Control - Backup Machine
Machine Compatibility
  • Software version 100.17.000.2043 or higher.
  • SKBIF PCB (34-4510) firmware version 6.0 or higher.
    Note: To verify the SKBIF version: Press the [DIAGNOSTIC] button and go to the System tab.
  • RJH-Touch
SKBIF and RJH Firmware Download
Login to the Haas Portal.
Download the latest NGC software.  Unzip the file and save it to the root of the USB device.
SKBIF Firmware Download
On the portal, go to Service> Documents and Software> Control_Software> Next Generation Control> SKBIF PCB Firmware
Select SKBIF-NGC_SERVICE__06xx.zip,  this will begin the file download.
On the portal, go to Service> Documents and Software> Control_Software> Next Generation Control> RJH Firmware
Select RJH-NGC_Service__APP_02xx.zip,  this will begin the file download.
When the download is complete, unzip and copy the .hex [2] files inside the USB device under HaasUpdateData/SKBIF/ [1].
Firmware Update
Power off the machine.
Press [POWER ON] while you press and hold the U button.
Press 4. To update the SKBIF / RJH Firmware  [1].
The firmware file will be detected and show on the menu [2].
Press 1. To update the SKBIF firmware.
Press 2. To update the RJH Firmware.
A SKBIF or RJH UPDATER screen will appear.
Select the firmware file [3].
A warning message will appear.
Press [ENTER] to proceed with the firmware install [4].
After the update is successful, Cycle the power on the machine.
Verify the SKBIF / RJH version.
Press the [DIAGNOSTIC] button.
Navigate to the System tab.
