Wi-Fi Camera Option - Installation - AD0445
Service Home How To Procedures Wi-Fi Camera Option - Installation - AD0445
24.3 WiFi Camera Option - Installation
Recently Updated Last updated: 02/17/2021
AD0445
This procedure will show you how to install the Wifi Camera option all machines.
This procedure applies to the following parts kit:
  • 93-1000291: Wi-Fi Camera Kit
App Download and Activation
Download the mydlink Smartphone application to your mobile device and set up an account.
 NOTE: To be able to stream through multiple devices, it is only possible by using the same account on each device. It will not stream the video feed on different accounts.
Scan the QR code that is printed on the Quick Install Card that comes with the kit and complete the setup.
Note:  If the the card is damaged, lost, or missing from the kit you can scan the QR code that is located on the back of the camera.  Remove the camera housing cap to get to the camera.
Removal / Installation
Press [POWER OFF].  Set the main circuit breaker to the [OFF] position.
Position the camera assembly [3] with the provided magnetic base to your desired viewing location within the enclosure.
Route the cable through an enclosure opening to the electrical cabinet.  We recommend routing the camera cable using existing cable routings.
Use the provided cable magnets to hang the cable within the enclosure.
Route the camera power cable [1] inside the electrical cabinet as shown.
 Note: There is a power extension cable included in the kit if more length is required.
Connect the camera power cable to the power supply [2].
Connect the power supply to the GFCI outlet [3] inside the electrical cabinet.
Note: Machines equipped with the 24V Worklight /HIL system will not have a GFCI outlet, it will be a regular outlet
Camera Test
Verify that the camera is operating by selecting your device on the mydlink application.
Make any necessary adjustments to the camera housing.
Troubleshooting
The WiFi Camera will not connect to the QR code printed on the Quick Install Card. The printed QR code may be damaged or printed incorrectly. Remove the camera housing cap and try the QR code located on the back of the camera.
