Accessory Tooling Block (ATB) - Installation - AD0363
Service Home How To Procedures Accessory Tooling Block (ATB) - Installation - AD0363
Recently Updated Last updated: 03/11/2026
Revision 2
AD0363
Revision A - 3/2026
- Jump to Section - 1. Introduction 2. VF Installation (3 steps) 3. UMC Installation (2 steps) 4. GM Installation (4 steps) Back to Top
Updated
This procedure tells you how to install the Accessory Tooling Block (ATB) option.
For machines not running flood coolant, please use:
  • 20-7277: SPINDLE ACC BLOCK NO/CLNT
For machines running flood coolant, order one of the following kits:
Spindle Front Cap with 6 Holes:
  • 93-1000071: ACCESSORY TOOLING BLOCK (VF-6 through VF-14)
  • 93-1000072: ACCESSORY TOOLING BLOCK (VF-1 through VF-5, UMC)
Note: This procedure can also be used when replacing PN 20-7265D with PN 20-7265E.
Spindle Front Cap with 10 Holes:
  • 93-1000982: ACCESSORY TOOLING BLOCK (VF-6 through VF-14)
  • 93-1000981: ACCESSORY TOOLING BLOCK (VF-1 through VF-5, UMC)
Note: Ensure that the ATB is compatible with your machine and tooling. See images below for reference.
Note: Ensure to select correct ATB kit with the corresponding machine. Customers with VMCs will order ATB 93-1000982 / 93-1000981 if the front cap has 10 holes [1]. Customers with VMCs will order ATB 93-1000071 / 93-1000072 if the front cap has 6 holes [2].
Updated
Ensure that the ATB you are ordering is compatible with your tooling.
93-1000071 and 93-1000072 use 20-7265E [1], which has a mounting hole. 93-1000982 and 93-1000981 use 20-10578 [2], which has a mounting hole.
20-7277 [3] has a slot, and not a mounting hole.
VF Installation
Do this step for machines with PCOOL.
Remove the plug [1] for the coolant ring.
Install the ATB [2] with the (2) 10-32 x 1/2" socket-head cap screws [SHCS].
Install the elbow fitting [3] for the coolant ring.
Install the elbow fitting [4] for the ATB.
Connect the hose [5] to the (2) elbow fittings.
Do this step for machines without PCOOL.
Remove the plug [2] for the coolant ring.
Install the ATB [1] with the (2) 10-32 x 1/2" socket-head cap screws [SHCS].
Do this step for machines with a 50-Taper Spindle.
UMC Installation
Remove the NOZZLE CLNT [1] and the DRAIN TUBE [2] from the spindle mount casting.
Install the ATB [3] with the (2) 10-32 x 1/2" socket-head cap screws [SHCS].
Install the fitting [1] to the spindle mount casting.
Connect the hose [2] to the fittings.
GM Installation
Install the plug fitting [2] into the ATB.
If the cap on spindle head is in a position for the tool changer arm to hit the ATB, unbolt the cap and rotate it one bolt hole and re-install.
 Note: If there are shims under the spindle cap, be sure not to pinch them.
