Coolant Chiller (COOLANT CHILLER)
Product Image
GET QUOTE
Coolant Chiller
    CNY ONLY
Stabilizes coolant temperature
  • Stabilizes coolant temperature
  • Increases thermal stability
  • Reduces part variations caused by thermal changes
  • Removes heat generated by the machining process
  • Stabilizes the temperature of the entire machining environment
Our Coolant Chiller reduces the temperature of the machine’s coolant before it is circulated through the machine. The chilled coolant removes heat generated by the machining process to increase thermal stability.
  • Option Info
  • Details
SERVICE DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
Service Documents
VIDEOS
Coolant Chiller
Cool your coolant before it cycles through your machine, to help stabilize the temperature of the machining environment, and reduce thermal variations.
Operation
The Haas Coolant Chiller reduces the temperature of the machine’s coolant, before it is circulated through the machine. The system is effective whenever the flood coolant pump is on.
Warm coolant from the tank (red hoses in the illustration) is pumped through a filter and into the Chiller. The Chiller removes heat from the coolant, and delivers the chilled coolant (blue hose) to the spindle head and coolant nozzles.
  • Reduces part variation caused by thermal changes
Capability
The Coolant Chiller runs continuously, and has a sliding lever on the side of the unit to control the temperature. When set to the max cooling power, the Chiller cools the coolant at a rate of 1-degree Fahrenheit per 10 minutes of coolant flow.
Verify the Temperature
To verify the temperature of the coolant, press the [DIAGNOSTIC] key, and navigate to the GAUGES tab to see the current coolant temperature.
  • Excellent for mold making applications
  • Beneficial in all applications that produce high heat
Need More Information?
