High-Flow Coolant Pump (CPK-HF)
Product Image
GET QUOTE
    CNY ONLY
More coolant pressure for TM Series
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
This high-flow coolant pump upgrades the standard 1/4 hp (186 W) pump to a 1 hp (0.75 kW) pump that pushes 12 gpm @ 30 psi (45 L/min @ 2 bar) @ 60 Hz, providing greatly increased coolant pressure to the cutting tool. Activated via M-code or the keypad, the high-flow coolant pump will clear chips out of the way of the cutting tool in jobs that produce a lot of chips. You’ll see nicer part finishes, and extended tool life that will save time and money.
  • Allows higher cutting speeds for cycle time reduction, and prevents re-cutting chips
  • Increases tool life by clearing chips during deep-hole drilling and blind-pocket milling
  • Improves surface quality
  • Activated by M-code, or directly from the control pendant
Need More Information?
