Coolant Pump Kit (CPK-MM)
Product Image
GET QUOTE
Coolant Pump Kit
    CNY ONLY
The standard coolant system for MM Series
  • Option Info
OVERVIEW
VIDEOS
AVAILABLE ON THESE MACHINES
This kit includes a 1/4 hp (186 W) pump that delivers 6 gpm @ 10 psi (22.7 L/min @ 0.7 bar) to the cutting edge of the tools. The system is activated via M-code, or from the control pendant.
  • Allows higher cutting speeds for cycle-time reduction, and prevents re-cutting chips
  • Increases tool life by clearing chips from the cutting zone
  • Improves surface quality
VIDEOS
Coolant Pump Simple Maintenance
Orville gives some quick tips on keeping your coolant pump running at full efficiency.
Coolant Pump Troubleshooting
In this video, Service Engineer Andrew shows you how to troubleshoot your Haas flood coolant pump. Whether you feel your pump is excessively noisy, or doesn't have the flow it should, before assuming it needs to be replaced or serviced, watch this video and let Andrew walk you through the steps to troubleshoot your pump.
If Your Flood Coolant Pump Isn't Working...
If the Flood Coolant Pump on your Haas machine isn't pumping coolant, take a look at this video. Here we look at everything from the basics; like not having it plugged in correctly, to things like electrical issues and correct electrical phasing.
Need More Information?
