Gantry Router Coolant System (CS-GR)
Product Image
GET QUOTE
    CNY ONLY
Complete coolant system for GR and GM Series
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
This complete coolant system for Haas GR machines includes a 95-gallon (360 liter) coolant tank and pump. Machining with coolant allows higher cutting speeds to reduce cycle times, and prevents chip re-cutting for better surface finishes. The system is activated via M-code, or directly from the control pendant.
  • Increases tool life by clearing chips and lubricating the cutting tool during machining operations
  • Allows higher cutting speeds for cycle-time reduction
  • Improves surface quality
  • Activated via M-code, or directly from the control pendant
Need More Information?
