Enclosure Exhaust System (ENCL EXHAUST)
Product Image
GET QUOTE
    CNY ONLY
Fast, affordable mist extraction
  • Option Info
OVERVIEW
DOCUMENTS
VIDEOS
CUSTOMER TESTIMONIALS
AVAILABLE ON THESE MACHINES
Start loading parts sooner, without waiting for the coolant mist to clear from the machine enclosure. The Haas Enclosure Exhaust System keeps the machine’s interior clear of mist and smoke generated during the machining process, improving visibility and allowing for faster workpiece exchange. The Enclosure Exhaust System mounts easily to the enclosure, and is activated and powered by the machine.
  • Uses a powerful, low-vibration fan with 150 cfm (4.24 m3/min) nominal flow
  • Automatically detects clogged filters
  • Powered directly from the CNC control
  • Runs automatically when the spindle fan is on for energy efficiency
  • Easily connects to shop ducts via the standard 10" (254 mm) exhaust port
NOTE: This is not an air filtration system. It is a mechanical system that removes coolant mist and smoke from the enclosure and exhausts it outside the machine. If air filtration is required, aftermarket sytems are available that can be connected via the standard 10" (254 mm) exhaust port. Please contact a 3rd-party specialist to address your specific needs.
Service Documents
VIDEOS
Given how important cycle-time reduction is these days, having machine operators waiting around for coolant mist to dissipate from a machine’s enclosure before changing parts is an expensive waste of time. That’s why Haas engineers designed an Enclosure Exhaust System that is easy to use, simple to maintain – and, best of all, costs about half as much as what the competition offers.
Actron Engineering
Need More Information?
