Haas Chip Lift (HAAS CHIP LIFT)
Product Image
GET QUOTE
Haas Chip Lift
    CNY ONLY
Convey chips into a standard barrel or hopper
  • Option Info
  • Details
OVERVIEW
SERVICE DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
The Haas Chip Lift is a belt-type chip conveyor that collects chips from a machine’s side-discharge auger chute, and conveys them into a 55-gallon drum or hopper. The unit is plugged directly into the machine, and can be moved from machine to machine. The conveyor’s intake hopper can be oriented for discharge toward the front, side, or back of the machine. The Haas Chip Lift is ideal for high-volume chip production or machine cleanup.
NOTE: Not compatible with front-discharge augers or chip conveyors.
  • Belt-type chip conveyor discharges at barrel height
  • Easily moved from machine to machine
  • Powered directly by the machine
  • Can be positioned to the front, side, or back of the chip chute
SERVICE DOCUMENTS
VIDEOS
Haas Chip Lift
The Haas Chip Lift is designed to make every machinists life easier, and allow for your machine to run lights out. This takes the chips that are removed from the machine and deposits them into large barrels. No more taking small containers of chips and dumping them into barrels manually.
Chip Lift Benefits
The Haas Chip Lift collects chips as they are discharged from a machine’s side-discharge auger chute, and conveys them to barrel height – 34.5" (876 mm) – so they can be collected in a standard industrial barrel or large chip bin.
The Chip Lift’s intake hopper may be oriented to discharge chips to the back, side, or front of the machine, depending on customer needs and space requirements.
The Chip Lift is fully portable, and easily rolled from machine to machine for daily chip collection, or to the machine generating the most chips for less frequent maintenance.
  • Save time by collecting chips in larger barrels or chip bins that can be emptied less frequently
  • Included safety skirt protects operators from moving parts
  • Fully portable design is easily moved from machine to machine
  • Works well with steel, aluminum, and most common materials
  • Plug-&-Play interface with the Haas Control
  • Power is supplied directly from the Haas machine
  • Automatically reverses if a jam or overload occurs
  • Activated via M-code, or manually from the control pendant
  • Control Settings to adjust the interval and duration of operation
  • Automatic operation increases energy efficiency
  • Steep, 60-degree lift angle minimizes footprint
  • Heavy-duty hinged-belt for minimal maintenance
Chip Lift Compatability
The Haas Chip Lift is compatible with all Haas machines with an NGC control that have a chip auger installed, and a side-discharge auger chute with a discharge height of 26" (660 mm). The auger may be a Standard Feature or an Option, depending on the machine model.
  • The Haas Chip Lift is NOT compatible with Haas lathes, which do not have an auger option
  • The Haas Chip Lift is NOT compatible with the Multi-Auger Chip Conveyor (MACC-2) option
Field-install kits are available. Contact your local HFO for information.
Chip Lift Automatic Operation
The Haas Chip Lift and the Auger are programmed and operated simultaneously by the same M-code and Control Settings shown below.
  • M31 starts the belt-style conveyor in the forward direction to remove chips.
    • Once started, and the machine is in cycle, the conveyor will run for the time specified in Setting 115 CONVEYOR ON-TIME, and then shut off.
    • Once started, and the machine is in cycle, the conveyor will restart after the time in Setting 114 CONVEYOR CYCLE, and run for the time specified in Setting 115.
    • While the machine is in cycle, you can start the conveyor by pressing the [CHIP FWD] button on the keyboard. Once started, Settings 114 and 115 have the same effect as described above.
    • If Setting 114 is set to zero, automatic auger operation will not occur.
    • Setting 196 is an energy-saving timer to shut off the conveyor during machine idle time.
  • M33 stops all automatic conveyor operation while in cycle.
    • Manually stop the conveyor while in cycle by pressing the [CHIP STOP] button on the keyboard. This stops all automatic conveyor operation while in cycle.
Chip Lift Manual Operation
The Haas Chip Lift and the standard auger are operated simultaneously, by the same buttons on the Haas Control. The settings mentioned above also affect the conveyor when operated manually,
  • Press the [CHIP FWD] button on the keyboard to start the Auger and Chip Lift Conveyor in the forward direction to remove chips
  • Press the [CHIP REV] button on the keyboard to start the Auger and Chip Lift Conveyor in the reverse direction to clear a jam. The Auger and Chip Lift Conveyor remain on in reverse only while the button is pressed
  • Press the [CHIP STOP] button on the keyboard to stop the Auger and Chip Lift Conveyor
Need More Information?
