Part Hole Blaster (HOLE BLASTER)
Product Image
GET QUOTE
Part Hole Blaster
    CNY ONLY
Clear chips from holes with high-flow air
  • Option Info
OVERVIEW
AVAILABLE ON THESE MACHINES
The Haas Part Hole Blaster is a rigid air nozzle that mounts to the Programmable Coolant Nozzle to blast high-pressure air into holes and deep pockets to blow out chips and coolant. Activated by M code, the air blast is turned on and off via the part program.
NOTE: Requires the Haas Programmable Coolant Nozzle.
  • Blasts chips and coolant from holes and pockets
  • Adjustable position via the Programmable Coolant Nozzle
  • Controlled via M-codes in the part program
Field-installation requires a Programmable Coolant Nozzle built after 07/01/2022, and NGC software release 100.22.000.1000, or later.
  • INSTALLATION GUIDE
Available on These Machines
Need More Information?
