Minimum Quantity Lubrication (MIN QTY LUBE)
Product Image
GET QUOTE
    CNY ONLY
  • Reduced chip welding
  • Activates and deactivates via M-codes, or manually from the control pendant
  • Nozzle retracts for tool clearance when not in use
  • Comes with Haas-recommend oil, and works with a variety of fluids
The Haas Minimum Quantity Lubrication (MQL) system delivers a steady blast of compressed air and a small quantity of cutting oil directly to the cutting tool to provide lubrication, reduce heat, and remove chips. This extends tool life, improves surface finish, and in some applications, eliminates the need for coolant during milling, drilling, and tapping operations. MQL works in conjunction with the Haas Automatic Air Gun (AAG) option, and includes an oil reservoir, adjustable spray nozzle, and pressure gauge/regulator. Note: Requires the Haas Automatic Air Gun (AAG) option.
DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
Service Documents
VIDEOS
MQL Advantages – The Haas Minimum Quantity Lubrication System
Can’t use water-based coolant on your parts . . . but still need to keep your cutting tools lubricated? The Haas Minimum Quantity Lubrication System can help you out.
Need More Information?
