Coolant Tank Oil Skimmer (OIL-SKIMMER)
Product Image
GET QUOTE
    CNY ONLY
Extend Coolant Life and Save Money
The Haas Coolant Tank Oil Skimmer is an integrated solution for keeping your coolant tank free of tramp oils. It saves you time and money by extending the life of your coolant and reducing coolant maintenance.
  • Removes tramp oils directly from the coolant surface
  • Extends coolant life by minimizing bacteria growth
  • Plugs into the GFI outlet of the machine, or into any 120VAC outlet
  • Can use an electrical timer to control operation
A Simple Upgrade with Big Benefits
Keep your coolant cleaner and your machine running more efficiently with the Haas Oil Skimmer. By removing tramp oils from the coolant surface, it helps extend coolant life, reduce maintenance, and improve overall machining performance. It's a simple upgrade that saves time, lowers coolant costs, and helps you get more from your Haas machine.
BUY DIRECT NOW ON HAASTOOLING.COM
  • Option
OVERVIEW
SERVICE DOCUMENTS
VIDEOS
AVAILABLE ON THESE MACHINES
Oil Skimmer Machine Compatibility
  • You can install the Oil Skimmer on machines that have an external 45-gallon (170 L), 55-gallon (208 L) or 95-gallon (360 L) coolant tank.
  • ST-10/15/L machines: Require Oil Skimmer Mount Bracket Kit (P/N: 93-1001137). ST-10/15/L HPC option is not compatible with the Oil Skimmer.
The coolant tanks in the list below have a hole and a slot in the coolant tank cover for the Oil Skimmer:
  • 95-gallon (360 L) coolant tanks made after Feb 2019
  • 55-gallon (208 L) coolant tanks made after May 2019
*For all other machines, you must use the Tank Cover Template to make the hole and the slot in the coolant tank cover.
Service Documents
VIDEOS
Option Spotlight - Haas Coolant Tank Oil Skimmer
Coolant tanks and systems can easily become contaminated with unwanted oil and bacteria which can effect how your machine produces parts. Mark talks about how the Haas Coolant Tank Oil Skimmer can extend the life of your coolant and keep your machine running efficiently.
Overview of the Haas Coolant Tank Oil Skimmer
The Haas Coolant Tank Oil Skimmer reduces your coolant maintenance, helps keep your Haas machine run cleaner, and extends your coolant life by removing any tramp oil that enters your coolant tank. Check out this quick overview of how the Haas Coolant Tank Oil Skimmer can help your machine.
Time Lapse of the Coolant Tank Oil Skimmer
How well does the Haas Coolant Tank Oil Skimmer really work? Watch this time lapse as the skimmer removes all unwanted oil from this contaminated tank!
Need More Information?
