Area Scanner, 4 Meter (AREA SCANNER-4M )
Product Image
GET QUOTE
Area Scanner, 4-Meter
    CNY ONLY
Laser Protective Barrier for Cobots and Robots
  • Option Info
  • Specs
OVERVIEW
DOCUMENTS
AVAILABLE ON THESE MACHINES
Laser Area Scanner Kit. This compact, high-tech, protective barrier for robots and cobots uses infrared laser beams to scan the surroundings in two dimensions to detect intrusions. Provides 275° of coverage, with a 13' (4 meter) sensing distance.
  • Compact, while providing large area coverage
  • Configurable scanning areas
  • Multiple sampling to set number of times an object must be scanned before reacting
  • Multiple object resolutions to detect different sized intrusions
  • Sick Datasheet
  • Sick Operating Instructions
  • Sick Mounting Instructions
SERVICE DOCUMENTS
Type Area Scanner, Kit
Robot Series HC5 (5kg x 800mm), HC10 (10kg x 1000mm), HC15 (15kg x 1300mm), HRP-1, HRP-2
Sensing Distance 0.0-13.1 ft \ 0.0-4.0 m
Warning Sensing Distance 0.0-131.2 ft \ 0.0-40.0 m
Scanning Angle 275°
Operating Temperature Range 14-122 °F \ -10-50 °C
Input Voltage 24V DC
Current Output 250.0 mA
Response Time 70.0 ms
Brand SICK
Need More Information?
