High-Intensity Lighting (HIL-24V)
Product Image
GET QUOTE
High-Intensity Lighting, 24V
    CNY ONLY
Brightens your machine’s workspace
  • Overview
  • Send Info
Tired of not having enough light to properly load or inspect your parts in the machine? The High-Intensity Lighting option includes a pair of super-bright LED lights that can be easily adjusted to perfectly illuminate your machine workspace. These energy-efficient lights turn on automatically when the doors are opened, and turn off when closed. They can also be turned on/off manually. Uses 24V LED lights and a dedicated power supply to provide constant, flicker-free operation. For machines with 24V light systems only.
  • Automatically turn on when the door is opened, and turn off when closed
  • LED lights provide bright light without heat, and save on energy costs
  • Bright, even illumination of the machine workspace
  • Adjustable position for optimal results
  • For 24V systems only
  • Installation Guide
Need More Information?
High-Intensity Lighting Option
The High-Intensity Lighting option provides great light right where the machinist/operator needs it the most. These LED lights use low amounts of power, stay cool and are completely adjustable.
Mill High-Intensity Lighting
Check out Haas' High-Intensity Lighting option for our VMCs. These super bright LED work lights illuminate everything in your machines work envelope. They're easy to aim at whatever you need to see better and they're long lasting and energy efficient.
Lathe High-Intensity Lighting
Haas' High-Intensity Lighting option for our ST series lathes. Just like on the mills, they're easy to aim at whatever you need to see better. And there's no need to worry about jury rigging wires for power, they come wired into the machine and switch on and off automatically.
